585,902 active members*
4,247 visitors online*
    Dec 2014
    187
    Solving Out of square axis
    Hello everyone, my 900x600 bed seems to be out of Square to the gantry as cutting 2 circles and placing them on top of each other gives different shapes. Can anyone direct me to a detail method of re-aligning the gantry so that’s it’s square to the x axis
    thanks in advance
    Sep 2006
    245
    Re: Solving Out of square axis
    I think I would try cutting squares so it is easier to measure the exact amount of error. Measure the diagonals and you should be able to calculate how far to move to correct it.
    I recently saw a large commercial duty machine and it had a mechanism to re-square the gantry. One end of the X axis has 2 hard stops that you bring the gantry towards when it is powered down. When both sides touch the hard stop, it is square or at least within a mil of being square. The stops had a screw to adjust the exact stop position, but that only needs to be set up once.
    An alternative is to position sensors and use a routine that sneaks each side up to their sensor independently until both sides trip the sensor at the same time.
    Steve
  1. Having a couple of issues that need solving
    By strohkirchw in forum Taig Mills / Lathes
    Last Post: 03-10-2011, 05:37 AM
  2. Coolant Problem Solving
    By coolantman in forum MetalWork Discussion
    Last Post: 02-06-2009, 12:36 AM
  3. solidcam part solving help
    By nero81 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-02-2008, 01:39 AM
  4. Problem solving forum?
    By lsfoils in forum Community Club House
    Last Post: 10-05-2003, 07:49 PM
