586,005 active members*
4,845 visitors online*
IndustryArena Forum > CAM Software > EnRoute > Enroute with AXYZ Series 8012 Router
    Nov 2017
    We are a sign shop here in NC. I am the Senior CAD Designer trying to do a little research. I am a CAD guy not generally a CAM guy, so please bear with me and my little understanding of the matter.
    We have an AXYZ Series 8012 router that does the bulk of our cutting and a Multi-Cam across the street in that does the rest. The Multi-Cam uses Enroute (We are on version 5.1). The AXYZ Series 8012 uses Toolpath for Windows which is a TERRIBLE and slow method compared to the Enroute enabled machine. We currently do not have a service contract with AXYZ, so they will not answer a single question. Currently I just use Enroute to process the DXF to import into Toolpath and hate that method.
    All I want to know is...can I use Enroute to directly run the AXYZ Series 8012? Or do I have to use it to solely generate the NC Code and then bring that into Toolpath? Is all I need is a post processor to help with the matter?
    Please help! PM or answer here!
    Re: Enroute with AXYZ Series 8012 Router
    Not familiar with Enroute or Toolpath, but generally, no, CAM software does not control the machine. I suspect the multiCAM has it's own control that accepts the g-code from Enroute, and Enroute is not actually controlling the MultiCAM.
    Yes, with a proper post processor, it should be as simple as loading the Enroute produced g-code into Toolpath.
  1. Replies: 1
    Last Post: 09-19-2017, 12:23 PM
  2. need help- post processor for mastercam needed for my axyz series 6010
    By ddemirovic in forum Post Processors for MC
    Last Post: 06-19-2017, 06:42 PM
  3. AXYZ Old Software needed 1995 series 4000
    By gtxkid in forum Uncategorised CAM Discussion
    Last Post: 10-08-2013, 10:06 PM
  4. Multicam 3000 Series vs AXYZ 5000 Series
    By adamfilip in forum Commercial CNC Wood Routers
    Last Post: 10-18-2010, 08:54 AM
