585,981 active members*
4,059 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > 8055T - SPD 1.35 spindle drive error 307 - dc bus voltage low
Results 1 to 2 of 2
    Sep 2014
    3
    Hi all,
    anybody has a clue or solution for Error 307 - dc bus voltage low?
    the spindle drive of a lathe ends up with this error.
    x,z drives work properly. when connecting the drive by rs232 to the pc, the dc bus voltage is always the same 387V even if the other drives show the correct voltage.
    any hint will be greatly appreciated.
    Dec 2019
    Hi all,
    any hint will be greatly appreciated.[/QUOTE]
  1. Fagor 8055T Error 214.
    By soapcy in forum Fagor Automation
    Last Post: 12-16-2019, 11:56 AM
  2. Spindle Voltage Error (EX06) on a Dainichi BX45 cnc-lathe
    By Sunppaa in forum Uncategorised MetalWorking Machines
    Last Post: 06-13-2017, 02:56 PM
  3. Replies: 0
    Last Post: 03-08-2017, 11:37 PM
  4. Replies: 0
    Last Post: 10-01-2015, 05:29 PM
  5. 8055T v3.13 E-504 error in parameter
    By captain_bas in forum Fagor Automation
    Last Post: 12-30-2012, 08:02 PM
