As you know , when we need to change tools or cutters during the woodworking, we shall use Auto Tool change CNC router machine.
The woodworking works need 2 , 3 or 4 and max 8 pcs different cutters.
Then OMNI CNC provide for you 2 options based on how many cutters or tools do you need to finish your work.
Option 1: When your work need 5- 8 tools or cutters to finish.
ATC with 8 tool magazines: OMNI Carrousel Type ATC CNC Router - YouTube
The machine configuration is as follows
Taiwan Taiwan Syntec controller+ Italy HSD Auto Tool Change spindle +Servo motor+8 tool magazines.
Option 2: When your work need 2, or 4 tools or cutters to finish.
We have the OMNI MHC CNC router, we also name it ATC machine with several spindles, the machine configuration is just as follows:
DSP controller with ATC function + several spindles+ Stepper motor+vacuum table.
The 1st spindle with engraving cutter, the 2nd spindle with cutting cutter, the 3rd spindle with V shape/3D cutter.
When this machine works, each spindle work separately: 1st spindle only do the engraving job, 2nd spindle only do the cutting job, the 3rd spindle only do the V shape profile.
doulbe spindle cnc router do cutting and miiling 18mm MDF work
https://youtu.be/4Gj71N0qxsU
