585,991 active members*
6,624 visitors online*
Results 1 to 10 of 10
    Aug 2016
    119
    Smoothie - onboard drivers in parallel?
    Hi all,
    In a nutshell, I'm trying to decide if I want to drive my gantry with a single stepper or 2 separate steppers.
    Question: If I choose to use a single stepper, the smoothieboard (individual drivers) won't handle the current I expect to need. Their website makes mention of slaving one of the drivers so that 2 steppers can be driven. BUT, can I use this method, but also parallel the driver outputs so that I can double the current to a single larger stepper motor?
    It makes sense to me, but I'm not getting any hits on my searches, only hits re: 2 steppers on one driver, or slaved steppers.
    Thanks everyone
    1943
    Re: Smoothie - onboard drivers in parallel?
    Use separate drivers for each stepper.
    Sent from my Z958 using Tapatalk
    Aug 2016
    119
    Are you saying it's not possible to take the output from 2 drivers and wire them in parallel?
    Feb 2008
    644
    Quote Originally Posted by Blackened View Post
    In general you cannot do this as the output Hbridges will not switch at the same times
    so you will either have poor current control or simply destroy the driver chips
    ( depending on the drivers decay mode )
    Aug 2016
    119
    Quote Originally Posted by PCW_MESA View Post
    Thanks PCW_MESA. I hoped the two drivers would be synced by the jumpers on the board. Electronics was never my strong suit though. What time scale are we talking here? Shorter time than the steppers would be effected by, in regards to one stepper lagging or leading the other (in the case of 2 steppers working from 2 separate drivers that have been slaved) ? If you traced the 2 outputs on a scope, would they be miles apart or just a degree or so? I suppose I don't even know if that would be ok lol so it's not very important. I'm just curious.
    Feb 2008
    644
    If the output stages are not perfectly synchronized you will likely get high side and low side drivers on at the same time,
    causing what is called "shoot-through" meaning a dead short across the stepper power supply, this can kill the output devices
    in microseconds
    Aug 2016
    119
    Ok, that makes sense. I got a shorter, but similar reaction to my question on the smoothieboard forum. So I'll assume that option is off the table.
    Aug 2016
    119
    Hang on a second. I've just had a further thought. What if I had an eight wire stepper? Could I split the phases/wiring to drive half with one driver, and the other half with the other driver? In effect, treating the single large stepper as if it's 2 smaller 4 wire ones? This is getting a bit complicated though. I think I'm leaning towards the 2 stepper per axis idea. Maybe once I have a simpler, working machine I'll explore this idea further. But until then, probably best that I go with a tried and tested method.
    Mar 2007
    2083
    its a pity the stepper drivers are not plug in modules like the Pololu A4988 stepper motor drivers
    at first sight connecting an 8 wire motor to 2 drivers is a better idea but the motor will act as a 1 to 1 transformer
    so the two driver outputs will still interact and probably damage each other
    the stepper drivers will need to work in sync and each IC set up to provide half the motor current
    it will not work without modifying one driver
    so they share a common set of current sense resistors , a common clock for the " chopper "
    current control and care full adjustment of the potentiometer to set the motor current
    even then its not going to be easy to ensure they share the load current
    If the smoothie board has the connector making the signals available
    It would be better to re-route the step & direction signals going to one axis and connect them to a high current driver
    John
    Aug 2016
    119
    Thanks John,
    Very valuable info there. I've discarded the whole idea, and will be using 2 steppers, 2 drivers (one slaved). The smoothieboard does have connectors to make the signals available to external drivers, I was trying to make use of the 2 unused onboard drivers rather than have an external one with greater current handling capacity. Oh well, if I fry a driver I have 2 more I can swap to lol
  1. Stepper Drivers, Smooth Steppers, and Parallel Ports - Am I missing something?
    By Nickolaus in forum CNC Machine Related Electronics
    Last Post: 01-15-2015, 04:40 PM
  2. why are parallel drivers bad?
    By atmk in forum Stepper Motors / Drives
    Last Post: 08-22-2014, 02:36 AM
  3. ready to connect drivers to parallel port
    By derkiow in forum Stepper Motors / Drives
    Last Post: 02-11-2011, 07:05 PM
  4. how connect drivers to parallel port?
    By D3L05 in forum Servo Motors / Drives
    Last Post: 10-25-2007, 02:30 AM
  5. Vexta Drivers to Parallel port, to KCAM
    By happytriger2000 in forum Stepper Motors / Drives
    Last Post: 04-23-2005, 07:05 PM
