Hello all,
I have a Hardinge AHC lathe that has been retrofitted for the Accu-Slide CNC system. Recently I have determined that it needs a new belt for the spindle drive. I will replace the lower belt also. I believe that the belts are original or at least the same part numbers as the original. The motor has been changed to a variable speed.
Has anyone here ever changed these belts, and could you possibly walk me through the procedure?
Thank you in advance!!!
Gary LaValley
gamila
