585,991 active members*
6,540 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > GRBL - UGS Controller Direction Understanding
    Jul 2016
    12
    Hello guys. I'm hoping that you can help a newb out with another question/issue that I am having with my new machine. I have been working with mach3 for a while now and seem to have a handle on that.
    I have since purchased an openbuild OX 1500 x 1500 machine and got it all put together. Below is the list of everything that I have set up.
    OX 1500x1500 Machine
    Nema 23 Motors
    48vDC Power Supply
    Panucatt Gradus M1 Pro with Bigfoot Controllers
    GRBL 1.1
    Universal G-Code Sender Controller software.
    $h sends my machine to the top left corner and z all the way up with home switches.
    My understanding with GRBL and typical CNC machining is that everything is working in the negative plane rather than positive. I typically use vectric to make signs and whatnot which puts me in the positive plane. I have even tried using the gcode that is attached since it was made for this machine to build a box for this machine. Below are my $$ settings as well. What I am having a tough time understanding and getting the machine to work is that whatever gcode I send I receive an "alarm 2" error. Which to me means that it is sending it to the positive plane which will not work with GRBL. I have tried resetting the working coordinates to 0 on all planes but I still receive the error. I don't understand how to set it to 0 at the corner of my material and it will actually run properly. Do I have to home then basically job my machine to the opposite max corner to start? That just seems inefficient, but maybe that's it. Please any help would be greatly appreciated. and let me know if there is anything further I should provide to help identify what I'm doing wrong.
    $0=10
    $1=10
    $2=0
    $3=1
    $4=0
    $5=0
    $6=0
    $10=19
    $11=0.010
    $12=0.002
    $13=0
    $20=1
    $21=0
    $22=1
    $23=0
    $24=50.000
    $25=300.000
    $26=250
    $27=2.000
    $30=12000
    $31=4000
    $32=0
    $100=53.440
    $101=53.440
    $102=397.870
    $110=7500.000
    $111=7500.000
    $112=500.000
    $120=100.000
    $121=100.000
    $122=10.000
    $130=1450.000
    $131=1450.000
    $132=60.100
    Attached Files Attached Files
    Aug 2006
    44
    Re: GRBL - UGS Controller Direction Understanding
    maybe I can help you ?
    where are you located ?
    I am in Los Angeles .
    please email me we need to connect with online messengers.
    [email protected]
    Apr 2015
    113
    $10 should be 1. $23 is the setting you must change, i forget what mine is, but I reversed the Y axis ( = 2)
    Luthier/Woodworker/Machinist in NS, Canada.
  1. 109JB's User interface for the Arduino GRBL controller
    By 109jb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-14-2017, 06:51 AM
  2. Replies: 1
    Last Post: 08-19-2016, 11:57 AM
  3. DIY L298N Controller with GRBL Wiring Question???
    By Rymanvw in forum DIY CNC Router Table Machines
    Last Post: 03-05-2016, 11:17 PM
  4. My UHU Controller Run Motor In One Direction Only !!!
    By AbuTarif in forum UHU Servo Controllers
    Last Post: 07-21-2011, 05:16 AM
