585,667 active members*
3,983 visitors online*
    Mar 2014
    27
    Vacuum for a 4x4 CNC
    Hey all.
    Im still shopping for a 4x4 CNC. Either Camaster PT404, FMT Patriot 4x4, TechnoCNC HD-II & HDS.
    What size vacuum pump will be good for these machines.
    The usual stuff to be cut sheetwise. (Signmaker)
    Looking into haveing the table hybrid style. T-Slots also in top
    and maybe 2~4 zones for vac.
    Preferably single phase. Not looking to do the phase converter path.
    IIRC, the Patriot was offering
    5hp Becker vacuum pump KVT 3.80, 48 SCFM, 27′′ Hg, 220 Volt, 1-Ph, 60 HZ
    What to do...? I'll mostly be clamping but want that vac "just in case"
    yet not want a wimpy nor steroidic unit. Looking for Goldilocks.
    OK
    Thanks all.
    Re: Vacuum for a 4x4 CNC
    You won't do much better than that Becker pump, unless you go with a bigger Becker.
  1. MDF Vacuum not working - Adding holes to strengthen vacuum
    By TheHiggsBroson in forum WoodWorking Topics
    Last Post: 05-09-2017, 05:55 PM
  2. Vacuum pump size for vacuum hold down jig?
    By dawgwalker in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-21-2014, 03:07 AM
  3. Vacuum Fixture with Festo Vacuum Generators ?
    By yaji63 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-09-2013, 08:52 AM
  4. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
