585,885 active members*
5,922 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X3/SX3/G0619/G0463 > Does anyone have this x3/sx3 700mm (27.5 inch) table?
    Mar 2009
    296
    Found this very long table from little machine shop. To clear up any confusion, I believe early x3's only had tables about a foot long. The current x3/sx3 has a table about 21" 5/8 long and I just found this aftermarket one from little machine shop that's 27.5" long! But you can't see any threads on the leadscrew that comes with it in the picture. I don't know if it's 10 tpi or 8 tpi. I wonder if this table is hard on the ways in the base and saddle when you extend it all the way? It's 54 pounds hanging off one side! https://littlemachineshop.com/produc...ProductID=3845
    Sep 2012
    Re: Does anyone have this x3/sx3 700mm (27.5 inch) table?
    I bought that exact table from LMS a couple months ago. I just checked the leadscrew and the threads are 10 tpi. I haven't installed it yet so I can't vouch for the wear characteristics but I was planning on using it for a CNC conversion of my G0619 mill.
    Dec 2021
    Hi, I have one of the original X3's from Bob at Lathemaster with the 17.5" table. I replaced this with the LMS Sieg 27 1/2 table. I worried about the table length vis-a-vis the base and saddle size, but for my hobby uses I see no problem whatsoever. I am very happy with it. You can see my upgrade process at .
  1. CNC Router Table 900mm x 700mm
    By crocky in forum For Sale Only
    Last Post: 11-12-2016, 04:55 AM
  2. 6 inch 4th Axis Rotary Table STOPS
    By cuauhtemoc in forum Tormach Personal CNC Mill
    Last Post: 01-19-2012, 07:41 AM
  3. What size table for 90 Oz/INCH TORQUE motors
    By 44propmaker in forum DIY CNC Router Table Machines
    Last Post: 12-06-2007, 06:28 PM
  4. 4 inch rotary table for CNC, which has worked best
    By replicapro in forum Benchtop Machines
    Last Post: 07-15-2006, 04:49 PM
  5. Ballscrews for Bridgeport with a 36 inch table needed
    By mountainviewcnc in forum Bridgeport / Hardinge Mills
    Last Post: 06-20-2006, 06:25 AM
