585,722 active members*
4,035 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Nov 2012
    29
    TM 7045 FG cnc conversion
    Hello. I decided to share my cnc conversion project of TM 7045 FG mill. This milling machine is a clone of ZAY 7045, RF 45 and so on.
    The dovetails on the column was poor quality, so i decided to cut them away and install linear rails. A portion of lapping was required to make perfect flatness for linear rails.
    Aug 2008
    962
    Re: TM 7045 FG cnc conversion
    John,
    I am anxious to see more of your work on this conversion. You've already got my attention with the linear rail conversion!
    I've been thinking about that for some time now .. but have not proceeded because of the difficulty of tearing down the machine while inside the enclosure.
    My shop is so small, I would have to move a large shelving unit that is quite full to get the machine into the open where I could lift it out of the enclosure to tear it down!
    Your build might just be the thing that pushes me over the edge into doing it!
    Gary
    Feb 2007
    4553
    Question Re: TM 7045 FG cnc conversion
    John,
    Please explain the process you used to lap the rail mounting surface.
    Awesome work!
    Jeff...
    Quote Originally Posted by John1987 View Post
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Nov 2012
    29
    Quote Originally Posted by gd.marsh View Post
    John,
    Gary
    Actually, your build inspired me to purchase this mill and upgrade it. If my experience will be useful to you, it will be great!
    John,
    Awesome work!
    Jeff...
    I used the vertical slide from spindle head as a lapping plate. It has ground dovetails, so the flatness of it was pretty good. Also i took grinding paste for engine valves. Spread a little amount of the paste with some oil along the surface that you want to lap, put your flat lapping plate on top and go back and forth until the desired precision is achieved.
    Nov 2012
    29
    Once the dovetails were gone, i decided to make new spindle head, because the original one was too heavy (85 kilograms!) and it has Morse taper #4 spindle, which is very poor for continous working on cnc. There was some thick aluminum plates in my workshop, so i use them for spindle head. The spindle is custom made BT 30.
    Aug 2008
    962
    Very impressive!
    I have one of those spindle cartridges and have considered going that route. Will be interested to follow your progress.
    Can I ask what city in Russia you're in? I have a good friend who lives in Vologda. Haven't had a chance to visit yet but am hoping to make a trip there in the future.
    Gary
    Feb 2012
    41
    I like it so far. Nice. Going this route with the spindle myself.But have not purchased yet.
    Sent from my SM-G900R4 using Tapatalk
    Nov 2012
    29
    Very impressive!
    Gary
    I am living in Barnaul, not far from Novosibirsk. Not very big town in Western Siberia.
    Nov 2012
    29
    Installing ballscrew inside the column and motor plate on top of the column. I am using NEMA 34 steppers with encoders for all axis.
    Sep 2007
    300
    I have a RF45 retrofit in process and bought the rails for the Z. I won't get to the project for a while but am very interested in the thread.
    Nov 2012
    29
    Next, i made motor mounts for X and Y axis. They are similar.
    Attached Thumbnails Attached Thumbnails IMG_20141112_172501.jpg   IMG_20141114_154612.jpg   IMG_20141115_132724.jpg   IMG_20141115_150523.jpg
    Aug 2008
    962
    John,
    Any more progress? .. your machine is now inspiring me to do some rebuilding on mine ..
    Please post your progress .. things are looking great!
    Gary
    Nov 2012
    29
    Some hand scraping were done to ensure good contact between column and the base. Chip tray welded from 2mm thick hot rolled steel. Pretty tough thing...
    Add Z shaped grooves to the saddle for liquid oiling of the ways.
    Aug 2008
    962
    Looking great John .. really like the new head /spindle setup .. I've decided to go in that direction myself .. thinking about a welded steel head, but still only in planning stages right now so still not sure.
    Keep up the good work!
    Gary
    Nov 2012
    29
    Mar 2013
    88
    Nice!
    Sent from my iPhone using Tapatalk Pro
    Nov 2012
    29
    Actual view of the mill. Working 8 hours per day for 2.5 years.
    Mar 2013
    88
    So the machine has been complete and making parts for 8hrs a day for 2.5 years? That’s pretty impressive
    Nov 2012
    29
    Quote Originally Posted by ripperj View Post
    Correct.
    Nov 2012
    29
    Building a new head from cast iron to replace aluminum one. Also want to replace spindle motor and use 1.8 kilowatt AC servo.
Page 1 of 2 12
  1. DSP Conversion
    By redpiperbob in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-02-2015, 08:12 AM
  2. Lathemaster 7045 Mill Help Please
    By smokeeater908 in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2013, 03:27 AM
  3. 7045 30 taper spindle
    By Lob in forum Benchtop Machines
    Last Post: 11-10-2011, 04:55 PM
  4. servo conversion vs stepper conversion
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2008, 08:54 PM
  5. Some R45-7045 mill mods
    By davo727 in forum Charter Oak Automation Support Forum
    Last Post: 05-29-2007, 03:28 AM
