585,914 active members*
3,748 visitors online*
    Sep 2005
    540
    Y Axis Gib - PCNC 1100
    I have a question on the Y axis gib of a PCNC 1100.... To loosen or remove the gib, should the gib slide to the front or the rear of the machine?
    Robert
    Feb 2007
    1538
    Re: Y Axis Gib - PCNC 1100
    Hi - In the absence of any specific replies, you can look with a flashlight and note the thicker end - thicker end out loosens the gib.
    Cheers Cliff
    Sep 2015
    If the Tormach Operator Manual is correct: (9.3.3.2). Tighten is Front screw CW / rear screw CCW. That would make the gib slide out the front.
    Mike
    Sep 2005
    540
    Thanks for the comments. I have found conflicting info so thought a post here might help clear the fog.....
    Mike, I think tightening the front screw pushes the gib to the rear of the machine, It appears to me that the adjustment washer pushes on the actual gib. At first I thought the opposite and that it came out the front. After cleaning some of the gook out of the adjustment holes it looks like the adjustment screws are just threading into the base assembly and the shoulder washers move the gib.
    Robert
  1. Tormach PCNC 1100 axis motors and drivers
    By ErnieD in forum Tormach Personal CNC Mill
    Last Post: 04-18-2017, 01:40 PM
  2. [PCNC 1100] Y-Axis Gibb Issue
    By CNCer__ in forum Tormach Personal CNC Mill
    Last Post: 09-18-2016, 08:09 AM
  3. Tormach PCNC 1100 4 Axis CNC Mill
    By harry8 in forum For Sale Only
    Last Post: 05-18-2015, 08:01 AM
  4. Chatter only in X axis on Pcnc 1100
    By tmallard450 in forum Tormach Personal CNC Mill
    Last Post: 04-02-2015, 01:46 AM
  5. Tormach PCNC 1100 Fourth Axis Table as a C Axis
    By CNC-Dude in forum Tormach Personal CNC Mill
    Last Post: 01-08-2012, 12:49 PM
