Will a 64 bit version of windows 7 work in mach3 if I'm using an Ethernet smoothstepper ?
YES - based on personal experience.
Cheers
Roger
Are there any settings I need to adjust to make the 64bit version work or play well with others?
Nope. Just don't install the parallel port driver when you install Mach3.
I just completed a new screen set and I am looking for people to try it out
Based on your setup
"Will a 64 bit version of windows 7 work in mach3 if I'm using an Ethernet smoothstepper ?"
You are the perfect setup.
Are you interested?
If so you can get it here.
Licensing – nGeneYes, Inc – Software Working for Business
If not no worries
