High Quality Laser Meter For Laser Tube Power Gauge
A Laser Power Meter consists of a display and a detector. The Laser Power Meters has been calibrated at a given wavelength before shipping.
1. Outline
Laser Power Meter using the amount of heat absorption measurement principle, thermal sensor measure the scope is very wide in spectral width and power, very high spatial uniformity, Without spot size, spot location or spot uneven impact. Can measure continuous wave laser output power, pulse repetition rate can also measure the average laser output power.
2. Technical parameters
Name
Laser Power Meter
Model
HLP-200
Range
0-200W
Display
LED display
Minimum Resolution
0.1W
Photosensitive area
28mm
Spectral range
8-11um
Calibration Wavelength
10.6um
Response time
≤5S
Cooling
Water-cooled
Application
CO2 laser
Nonlinearity
±5%
Accept the surface
response nonuniformity
±5%
Consumption Power
≤8W
3. Advantage
Measure range 0-200w mini laser meter
1) Small size, easy to carry
2)Buit-in power supply, easy to use
3) Direct - reading, high - precision measurement
4. Usage
1) Put power meter to testing area immediately after press the start button, then waiting for the measurement.
2) The first sound means that measuring started, please continue to keep the smooth target surface during testing.
3) The second sound means measuring achieved.Please remove power meter immediately,do not stay for a long time.
4) The third sound means system power off automatically.
5) If after a long warning tone, the display shows"888.8", it means that the machine is breakdown,you could contact with the supplier, do not dismounting the machine arbitrarily.
* If the display shows "000.0",it means the temperature of the surface is too high or it is out of the measuring range. You can use the machine again after the temperature down.
Name:	power meter2.jpg
ID:	380867Click image for larger version.
Name:	power meter 4.jpg
ID:	380869Click image for larger version.
Name:	power meter 1.jpg
wwww.peakofglass.com
[email protected]
https://www.facebook.com/Lasertube
