585,753 active members*
4,122 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Keep screws and nut or are ballscrews a must.
    Aug 2012
    96
    So I pulled the trigger on a completely reconditioned Bridgeport J Head Mill. I plan on CNC retrofitting it myself. They put in brand new screws and nuts. Should I go ahead and replace them with ball screws? Seems like a shame to do it.
    I'd like to keep the screws because I plan being able to bump down to manual with a DRO for simple stuff. heard that ballscrews don't hold position well. I guess I can limit myself to one axis at a time by locking the axes (yes, that's the correct way to spell axis in plural).
    Feb 2014
    187
    Re: Keep screws and nut or are ballscrews a must.
    I thought of using my cnc conversion in manual mode - forget it, once you go cnc you don't go back - it's easier for me now to type a couple of lines of g-code than it is to twiddle the hand-cranks
    My screws were knackered so my decision was easier, if your screws and nuts are new then they might work ok in a cnc but you will have more backlash as they need it for clearance, ballscrews have none.
  1. Ballscrews - Where to get?
    By mrgame1988 in forum Benchtop Machines
    Last Post: 08-09-2015, 01:55 PM
  2. Misumi C10 ballscrews = Chinese C7 ballscrews?
    By Shalecnc in forum DIY CNC Router Table Machines
    Last Post: 08-08-2012, 08:42 AM
  3. Regular ACME Lead Screws Vs Precision Screws?
    By FreshMint in forum DIY CNC Router Table Machines
    Last Post: 11-27-2011, 03:51 PM
  4. Ball screws, Acme screws, threaded rod
    By DJ Morrow in forum DIY CNC Router Table Machines
    Last Post: 03-22-2007, 06:39 PM
