585,560 active members*
3,404 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > MAHO 600C - Philips 532 - spindle will not start after the tool change
    Mar 2017
    4
    Hello Everyone,
    First of all I would like to apologize for my bad english ...
    I'm working on the MAHO 600C (Philips532) that has the following problem (bought with this problem):
    After automatic tool changes, the M5 function remains on ... When I write for example S100 M3, the M5 goes off and the M3 turns on, but the spindle does not rotate.... when I press CLEAR CONTROL or enter M30 command everything returns to normal ... until the next tool change...there is no error on the screen...
    https://www.youtube.com/watch?v=LheX...ature=youtu.be
    In addition, I noticed that the programed spindle speed deviates from the one seen on the screen... for example if I set M3 S2000 on the screen it will write 1980 or similar....
    ...except the above mentioned machine works without any problems....but now it is impossible to create a program with multiple tool change until this malfunction is corrected...
    can anybody help me with this problem ?
    Mar 2017
    4
    Re: MAHO 600C - Philips 532 - spindle will not start after the tool change
    anyone
    anyone
  1. Automatic start/stop spindle on tool change?
    By Azalin in forum Mach Mill
    Last Post: 06-06-2017, 02:42 PM
  2. Spindle won"t start after a Tool Change!?
    By Driller2 in forum SprutCAM
    Last Post: 10-31-2015, 07:25 AM
  3. maho mh 600c
    By lucassatish in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-19-2013, 06:24 PM
  4. Maho 600C with Philips 432 CPU upgrade
    By nylas in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 06-03-2013, 11:31 AM
  5. Spindle start and stop and tool change
    By inman20k in forum BobCad-Cam
    Last Post: 09-15-2012, 10:35 PM
