584,858 active members*
4,307 visitors online*
Results 1 to 10 of 10
    Dec 2011
    18
    Hints about controller for specific use
    Hi!
    Right now I have two machines: a small router and a bit larger laser engraver. Both are DIY for most components. The first is controlled by a USBCNC CPU5A4E and the second by an Arduino with GRBL firmware and a driver shield.
    For the first machine I also have a HUGE cabinet with large drivers, power supplies and any possible connection... this is my "definitive" cabinet for any CNC in my life :-)
    However, both machines are too small for my needs and I really don't want two machines. I'm going to buy a larger one.
    Usually I need to laser engraving and milling the same stock, so it's not an option to continue with different setups.
    Unfortunately the USBCNC controller (that I like very much by the way) doesn't support the GRBL "laser mode" (G1 stops on every S changes).
    Hence I'm looking for a mid-high level controller with (at least) the following features:
    • 4 axis
    • standard step/dir/enable output
    • inputs for limit switches, probe, and aux pins (emergency stop, pause, run, etc...)
    • outputs for standard tools (spindle, coolant, mist) and some spare GPIO programmable from g-code (i.e. to turn on a relay)
    • PWM output for laser modulation bound to S value (not only on-off, I mean true PWM 0..100% duty cycle)
    • laser mode (G1 doesn't stop on S changes), and possibly ramp compensation (M3/M4 modes in GRBL)
    • inputs for pendant
    • better if works with Linux
    • nice to have, but not mandatory: scripting language to create macro and sdk to load/create plugins or customizing UI
    The ideal budget should be less than 500$, anyway I could revise it if it's worth to. I'm going to select the definitive controller for my life!
    Thank you for any suggestion.
    Dec 2013
    5717
    Re: Hints about controller for specific use
    I would look at Dynomotion Dynomotion Motion Control Boards for CNC Manufacturing and Robotics Applications or Galil Motion Controllers | Galil. The Galil controllers are quite expensive when purchased new, but very available on Ebay at various prices.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2011
    18
    As far as I understand they are very good motion controller but not specific for CNC - I mean it's unclear if they have all the features above and what software I need to use with them.
    Dec 2013
    5717
    Quote Originally Posted by _Mark_ View Post
    I have never used the Dynomotion controllers. But it's my understanding that they would meet all of your requirements.
    The Galil products meet all of your requirements. I use them on all of my CNC machines. I wrote my own CNC software, but the Galil products are compatible with Mach3 and other systems. I think Linux drivers are also available for the Galil products, but not sure what software is required.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2011
    18
    Glad to hear that. I will study the documentation deeper.
    15362
    Hi!
    • 4 axis
    The control you have you won't find much better without spending a lot more money
    Eding CNC would be your best choice for laser and mill control, next would be Acorn with Centroid control
    Eding CNC - PC based CNC control
    Acorn CNC controller, Step and Direction 4 axis CNC Control board with ethernet communication.
    Mactec54
    Dec 2011
    18
    As said I already own a USBCNC controlled (EdingCnc) but it is NOT suitable for laser engraving because the G1 movements are affected by the S value changes.
    About Acorn CNC I will investigate further but in the main page it's not highlighted this feature.
    Instead I've just asked to Planet CNC (https://planet-cnc.com/) and their products support laser mode.
    Aug 2016
    119
    Smoothieboard? Just need to reboot it to swap from laser to cnc mode. Assorted outputs. Scripted config file. Open source so if you're handy with code you can add anything it doesn't already have. I've got one for my Laser build in progress but I don't have specific experience re: router. GRBL mode.
    start [Smoothieware]
    If you need steppers >2A then it's got signal out for external drivers.
    Dec 2011
    18
    They look promising but apart the old v1 the others are still in development and no release date is given:
    Currently being designed, release in 2017, see here.
    Because v2 is being developed by awesome volunteers, we have no timetable or planned release date, so please stop asking.
    Aug 2016
    119
    Is the v1 fit for purpose?
  1. 2.5D first parts and hints
    By etzz in forum MadCAM
    Last Post: 03-23-2012, 01:08 PM
  2. Specific feed speed rates for specific wood
    By mcArch in forum WoodWorking Topics
    Last Post: 08-19-2008, 04:36 AM
  3. Are there specific router bits for specific materials?
    By fivefishcnc in forum Uncategorised MetalWorking Machines
    Last Post: 02-24-2008, 02:35 PM
  4. Need startup hints - day 1
    By designerpatrick in forum Milltronics
    Last Post: 11-21-2007, 04:23 PM
  5. Any helpful hints for tramming?
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-03-2006, 07:36 PM
