585,975 active members*
4,566 visitors online*
    Jun 2017
    5
    Flattening / planing hardwoods - best bits?
    Today I flattened a walnut slab with Onsrud’s 1.25” spoilboard cutter. I know it’s the wrong bit, but I wanted to give it a try. The good news is that the slab is nice and flat. Bad news is that it took forever and the tooling marks are prominent and a surprisingly huge pain to sand out.
    I’m looking at the Amana rc-2551 or the new rc-2255, which Amana claims can plunge 1/4” and then surface. Any experience with them? Other ideas? I’m looking for the best finish first and foremost; but obviously efficiency matters too.
    I have a ShopBot PRS standard with an HSD 2.2 spindle. Max 1/2” shank.
    Thanks!
    Re: Flattening / planing hardwoods - best bits?
    The best finish would come from a planer. A router is not the right tool if finish is the most important objective.
    Make sure your spindle is perfectly trammed, if you want to minimize tool marks.
    I plan on picking up one of those new Amana bits, but haven't gotten around to it yet.
    Jun 2017
    5
    I agree, but I can’t plane anything larger than 13” wide and don’t plan on investing in a large format planer. The spindle is square. You can’t feel the tool marks — no ridges.
    You could try slightly rounding the corners of the carbide cutters with a fine diamond stone.
  1. Flattening a helix in Bobcad
    By Forrest C in forum BobCad-Cam
    Last Post: 03-25-2014, 05:00 PM
  2. Flattening
    By Forrest C in forum Solidworks
    Last Post: 01-14-2014, 06:54 PM
  3. Flattening aluminum tube?
    By Konstantin in forum MetalWork Discussion
    Last Post: 09-07-2010, 07:36 PM
  4. Flattening
    By zachf in forum BobCad-Cam
    Last Post: 09-17-2009, 06:05 PM
  5. Flattening out a cone ???
    By Mr. LocoMartin in forum BobCad-Cam
    Last Post: 04-10-2009, 03:04 AM
