585,996 active members*
4,539 visitors online*
    Jan 2012
    12
    Need Help with 4th axis
    Hi I need help with 4th axis
    I can move the 4th axis back and foward on the keyboard but when I load the the Gcode to mach3 (wich is a thread that I want to cut on a 1 1/2 round wood) the 4th axis does not turn, only the Y axis moves along the round wood.
    but manualy I can turn it, What could be the problem is there a setting that I forgot I can not find it.
    I would appreciate if someone can help me.
    thanks.
    Re: Need Help with 4th axis
    Is the 4th axis setup as the A axis, and does the gcode have A axis moves in it?
    Jan 2012
    12
    Hi Thank you for answering so soon, I have ASPIRE SOFTWARE acording to this software I typed all the detais for that tipe of screw and the program writes the Gcode,
    this is the Gcode if you saw something wrong let me know please
    Regards
    Ivan
    ( Tornillo 4 )
    ( File created: Sunday, December 10, 2017 - 12:22 PM)
    ( for Mach2/3 from Vectric )
    ( Material Size)
    ( X= 239.389, Z= 19.050)
    ( Diameter = 38.100 mm)
    ( X Values are wrapped around the Y axis )
    ( X Values are output as A )
    (Toolpaths used in this file
    (Profile 1)
    (Tools used in this file: )
    (1 = V-Bit {55 deg10 mm} )
    N130 G00G21G17G90G40G49G80
    N140 G71G91.1
    N150 T1M06
    N160 G00G43Z50.000H1
    N170 S16000M03
    N180(Toolpath:- Profile 1)
    N190()
    N200 G94
    N210 Y0.000 A0.000 Z50.000 F900.0
    N220 G00 A0.000 Y0.000 Z25.400
    N230 G1 A0.000 Y0.000 Z17.550 F300.0
    N240 G1 A15274.274 Y359.200 Z17.550 F900.0
    N250 G00 A15274.274 Y359.200 Z25.400
    N260 G00 A0.000 Y0.000 Z25.400
    N270 G1 A0.000 Y0.000 Z16.050 F300.0
    N280 G1 A15274.274 Y359.200 Z16.050 F900.0
    N290 G00 A15274.274 Y359.200 Z25.400
    N300 G00 Z50.000
    N310 G00 Y0.000 A0.000
    N320 M09
    N330 M30
    Aug 2008
    406
    WOOPS
  1. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  2. Replies: 0
    Last Post: 04-27-2016, 04:08 PM
  3. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  4. Replies: 0
    Last Post: 08-04-2013, 05:30 AM
  5. 5-axis, 4-axis, and 3-axis CNC Router manufacturer
    By roctech in forum Roctech CNC Routers
    Last Post: 05-24-2012, 09:12 AM
