Re: Are Twin spindle Twin turret lathes as complex as they look?
hey jmk, i have used such collets a while ago, and onestly i forgot about them
try to look for such an item at the supliers arround your area; maybe someone has something
if not, there may still be a solution :
... craft a part, like a collet, without grooves, from a hard material
... drill them on side
... take this part to the edm wire and cut the grooves how you like
... when you insert the tool shank, use also a bearing ball, or some kind of an insert, that will block the tool from slipping out; this element has to be softer then the collet, otherwise it may deform the collet
about modifing the arbor of the live holder, there may be a solution to take it apart, send the arbor at a shop with veterans ( so someone outthere should know how to craft it; such an item is not complicated for somepersons that may be working in a local shop; my point is that you don't need to contact a specialized brand )
kindly
