585,727 active members*
4,065 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Eccentric turn on with GIBBS V12
    Dec 2007
    49
    My boss saw it on You-Tube once.
    I am wondering if anyone has had any luck doing an Eccentric turn with GIBBS. I am on V12 and have 5-Axis module available to me from our milling dept. If you search YOU TUBE for Eccentric Turning, you will see what I am talking about. Basically, I am trying to do an offset turn without an offset fixture. Directly from GIBBS I am told that "No it is not supported and can't be done." From a reseller with a "Turning GURU", I am told yes it can, but you have to lie to it. You have to program a 5-Axis mill path with a ballmill on Y 0.0 and then edit the code to not turn on the live tool to make it work. So the spindle will move and the X and Z Axis will move, but the cutting tool stays at Y0. and just goes up and down in X and toward the chuck in Z. After that advice, I have heard nothing in reply to my next request, "Please show me how to do this." This was 1 year ago.
    My boss has since forgotten and now suddenly remembered about this. Now I need help if anyone can give it. I understand the concept. I have no idea how to pull it off. I have 3D experience with MasterCAM, but no 5-Axis experience with anything. 5-Axis hasn't come up much on the turning machines.
    May 2012
    83
    Re: Eccentric turn on with GIBBS V12
    pm me with step file
    Dec 2007
    49
    Quote Originally Posted by MACHINEFREAK View Post
    Thank you for the reply. I finally got a path from our reseller. I loaded it in machine and it will not break a chip while turning. It won't go fast enough without throwing an error alarm. I am off the hook and back to 3d machinining and 5 axis machining on it.
  1. Turn off Subroutines in Gibbs 2015
    By Sierevello in forum GibbsCAM
    Last Post: 07-26-2017, 10:03 PM
  2. eccentric turning
    By rcs60 in forum CNC Swiss Screw Machines
    Last Post: 11-16-2016, 06:32 PM
  3. eccentric turn milling
    By promach in forum Okuma
    Last Post: 12-01-2013, 03:47 AM
  4. How much eccentric it is ?
    By Ashish B in forum Hobby Discussion
    Last Post: 04-30-2012, 09:24 AM
  5. eccentric
    By hongjianming in forum CNC Swiss Screw Machines
    Last Post: 01-05-2011, 06:37 PM
