585,741 active members*
5,152 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > cincinnati V-CNC 500 1035 transformer over temperature
    Mar 2013
    59
    hi
    I have a cincinnati V-CNC 500 with Fanuc 21 control , alarm 1035 transformer over temperature , this machine no have a external transformer .
    I was looking for information ,finding that you should a jumper for closing the circuit but could you help me indicate me where i need put the jumper,please
    see attach pics
    thanks
    Dec 2006
    584
    Re: cincinnati V-CNC 500 1035 transformer over temperature
    Do you have the electrical prints?? Most of the time the machine is wired for 230VAC and can come with a optional 460 to 230 VAC step down transformer. In the prints you should have 2- 24VDC blue wires going to a transformer to indicate an over temperature condition. This input is a normally closed thermal switch that opens up when the temperature is exceeded and generates the error you are getting. If you don't have a optional transformer then you need to look at your electrical prints and tie the two blue wires together or jumper them.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
  1. SOLIDCAM POST PROCESSOR FOR SIEMENS 810D (DMG DMC 1035 Ecoline)
    By scottbryce in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-21-2019, 10:03 PM
  2. cincinnati milacron and step up transformer
    By JohnHennessy in forum Cincinnati CNC
    Last Post: 11-25-2017, 02:47 AM
  3. Adding a OMP60 spindle probe to a Dura Vertical 1035 Eco
    By zachrabbit15 in forum Mori Seiki Mills
    Last Post: 05-05-2015, 06:54 PM
  4. Temperature
    By rjsmith in forum CNC Swiss Screw Machines
    Last Post: 08-05-2010, 04:57 AM
