585,767 active members*
4,273 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Q: Deep (~9") Drilling Speeds & Feeds
    Dec 2017
    Question Q: Deep (~9") Drilling Speeds & Feeds
    Hello all,
    This is my first post on the site, so if I'm in the wrong forum let me know.
    I work at an automotive company, and in going through some of the G-code for some of our parts I saw some feed rates that seemed on the low side. I am considering upping the feed rate on the 5-axis deep drilling operations with the goal of reducing cycle time, and potentially increasing tool life which has always been an issue for us.
    Here are my current variables:
    Feed Rate = F23.0 IPM
    Spindle Speed = 4000RPM
    Cutting Feed = 23.0IPM / 4000RPM = 0.00575 IPR (this seemed high to me given our hardness)
    Tooling = 0.246” Twist Drill
    Stock (material) = SAE J431 Gray Iron; Average BHN = 232 over a sample of 415 units; over a Range between 207-255BHN
    Drilling Depths = ~9” maximum
    I’d like to start by making a jump to variables like this:
    Feed Rate = F30.0 IPM
    Spindle Speed = 6500RPM
    Cutting Feed = 30.0IPM / 6500RPM = 0.0046 IPR
    My questions are:
    1. Is this a good starting point?
    2. Will using a spindle speed this high likely give heat issues for a deep drill?
    3. Can I expect to see an increase in tool life when reducing the cutting feed?
    4. What spindle speed starts to become too high for a drill bit such as this?
    Dec 2013
    5717
    Re: Q: Deep (~9") Drilling Speeds & Feeds
    I would get some advice from your tooling supplier. I would think that a twist drill is not the right tool for this application. A gun drill with through high pressure coolant is typically used for deep hole drilling in a high production environment.
    Jim Dawson
    Sandy, Oregon, USA
  1. help drilling 500 .375" holes 3" deep aluminum help
    By vz58 in forum MetalWork Discussion
    Last Post: 06-23-2017, 12:26 PM
  2. Feeds and speeds drilling aluminum
    By henrikm in forum Material Machining Solutions
    Last Post: 02-12-2015, 07:36 AM
  3. Replies: 23
    Last Post: 01-23-2015, 11:57 PM
  4. Drilling speeds and feeds for 6063
    By jmc2010 in forum MetalWork Discussion
    Last Post: 07-18-2014, 07:24 AM
  5. Replies: 4
    Last Post: 07-03-2014, 04:47 PM
