Hope this helps someone out ...
https://www.ebay.com/itm/Sieg-X2-Min...l/322938379539
New System Pull - Took these off my brand new never ran never seen a volt of electricity ... Sieg X2D Mini Mill. All parts are STOCK NEW that came on the Sieg Mill - unless otherwise indicated below.
New stock motor with gear - as pictured - Sieg / LittleMachine Shop Part # 1128 [ $214 value ] 110VDC / 350 Watts
New stock PWM motor controller unit from Sieg for this mill. Sieg / LittleMachine Shop Part # XMT-1135 [ $160 value ]
Control Boxes - as pictured
Wire protective sheath - from stock mill
On Off Switch - from stock unit
On off lights and LED - new
Fuse holder
Motor Speed Dial - potentiometer
the motor and controller combined are valued new at over $375 - add the misc items in for another $30-50 new from other sources and this package is a real value of over $400 ! All items are new never used / never ran ...
If you would like to separate these items individually - please contact via ask seller a question - we can discuss
