584,861 active members*
4,717 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Upgrade of Huanyang vfd
Page 1 of 19 12311
Results 1 to 20 of 378
    Mar 2016
    18
    Hi all!
    I've been considering if upgrading my 2.2kw Chinese air cooled spindle cheap vfd. I was just wondering what people have and what they think of it in comparison? If it's worth it? Can you notice any difference in torque in general an at lower rpms?
    Also what models do you have/recommend.
    I've been looking at the Yaskawa V1000. Has anyone been using this with this type of spindle?
    Dave.
    15362
    Re: Upgrade of Huanyang vfd
    Quote Originally Posted by davemorl View Post
    Hi all!
    Dave.
    That's a very good VFD, but this won't solve, your torque at lower RPM, you have a air cooled spindle which has a minimum speed, they are not much good for anything below the minimum RPM of your spindle, they have max torque at the max RPM, so when trying to use them at lower speeds the torque / Hp drops off quite quickly
    Water cooled can cut at lower RPM than the air cooled spindles 6,000 is there minimum, but only have a useful cutting range from around 7,500 to 24,000 RPM
    Mactec54
    Mar 2016
    18
    Yeah I'm aware that the water cooled can run slower bit the torque is useless thats why I never got one. I am just wondering if a better VFD would give better torque that the cheap Chinese one at the lower RPM of the air cooled as I know the torque is not as good at the designed running frequency of 400hz. I'm assuming a better VFD is gonna impove things but it's weighing up if the improvement is worth the £400 and if its even noticable?
    Dec 2013
    5717
    I wonder if a sensorless vector VFD would work on a high speed spindle. Much flatter torque curve. But would it fry a high speed spindle if you ran it too slow? I dunno.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2016
    18
    I do believe that us what the V1000 is. I'm not 100% how it all works though but they say vector control is the new way to control motors instead of frequency variable drives which I think is what the Chinese Huanyang is.
    It uses computional power to monitor the feedback from the motor that's pretty much all I know haha! I could be wrong and I'm sure someone could tell me more who understands it better.
    What I'm wondering is if I use a better vector drive will I get a flat torque gradient so will I get constant torque throughout the speed range or closer to it than the Chinese drive at the lower RPM range like say 7500?
    I don't want to go below 7000rpm I know the spindle can't do it.
    It's just weighing up if what you get back for spending the money is worth it or just stick with the cheap drive?!
    I am hoping someone can tell me more
    ericks Guest
    My advise....buy an Industry approved motor and drive
    Mar 2016
    18
    You're talking 1000's for one of those motors. I agree if I had the cash I'd buy a Haas spindle or even better a VMC 😂😂
    I'm just trying to squeeze as much as possible from a cheap spindle for as cheap as possible for a hobbiest. ☺
    ericks Guest
    I understand..... Currently i am using a kress spindle/router. Teknomotor is my choice for the new machine, it good value under 1000 Aud.
    Mar 2016
    18
    Yeah I have been looking at them, I think that's all I'll be doing as well. I can always dream haha! Maybe one day!
    15362
    As I said a better quality VFD will make no difference, it's all about your spindle motor, more than what the VFD can do, the torque curve can be adjusted, but those that do if you go to far you will smoke the spindle
    Mactec54
    ericks Guest
    If i were you i would not buy the same drive. I looked at it's specifications and it does not look like it's approved anywhere! You will not be able to buy this product from a authorized supplier. If it is used in eg Australia and it causes your home to burn down then i am afraid you will have some difficulty.... Delta for example isn't my first choice but its approved here in Australia, in Europe and i am sure America too.... Just my opinion
    Mar 2016
    18
    Quote Originally Posted by ericks View Post
    Do you mean the Chinese one?
    I don't think I'll be getting another one to be honest. I think one of these
    https://www.motorcontrolwarehouse.co.uk/invertek-ode-3-220105-1f42-optidrive-e3.html
    Or the V1000.
    It's just weighing up the benifits of paying £200 more for the v1000 and will the more money be noticeable with performance?!
    ericks Guest
    https://www.motorcontrolwarehouse.co...idrive-e3.html
    Or the V1000.
    Yes i mean your Chinese drive... When you buy a descent drive then the most important thing to remember is to check the manual to make sure you protect the drive with the recommended fuse or breaker size and type. Proper selection will save your drive in case of serious motor failure eg motor "short" or motor earth fault. Proper mounting or panel cooling is also vital, i see many guys mounting their drives incorrectly. The manufacturer will indicate proper ventilation and clearance distances....
    .....re the V1000, Yaskawa make very good drives
    Jun 2017
    238
    I had one of the Chinese vfd. It lasted 5 months before the dreaded E.lu.5 error that will not reset. I've bought one of these as a replacement.
    https://drives-online.com/inverters/vacon0020-1l-0009-2
    It was 3 times the price. But the company were really helpful. They have pre programmed it for me and included a wiring diagram and remote control. I'm told it is a very reliable drive.
    Sent from my SM-G935F using Tapatalk
    15362
    Quote Originally Posted by potts43 View Post
    That looks like a well thought out drive with the cables Shield clamps in place
    Mactec54
    Jun 2017
    238
    Hi mac.....
    In the end I was told to get a danfoss vlt fc51 as the above drive didn't go to 400hz. I thought I'd have no issues. However the pot only goes from 0hz to 200hz even though it's set to go to 400hz. I've entered the figures Danfoss told me. But I guess 200hz is the same as 12000 rpm. I'm now very frustrated. I wondered if it was down to the 2 or 4 pole settings but can't see a parameter for that.
    Any ideas appreciated.
    15362
    Hi mac.....
    Strange they could not get you running correct, Danfoss make a very good drive
    Some VF Drives, the Poles are auto ranging as soon as the high Hz parameters at set, so may be nothing to worry about
    What do you have these Parameters set at
    3-02=
    3-03=
    4-12=
    4-14=
    Mactec54
    ericks Guest
    Not bad drives, we use a lot of VLT2800 and VLT5000 ones.
    You need to make sure you have set parameter 1-01 to [0] U/f
    otherwise you will be limited to a maximum of 200Hz
    Jun 2017
    238
    3-02=
    3-03=
    4-12=
    4-14=
    I believe I have 120 and 400.
    Jun 2017
    238
    Ericks you are a star that worked!!!
    If I press the Hand on button the supply doesn't run until I turn the pot. It then goes from 0hz to 400hz. A Brilliant start.
    Is it possible to replace it showing hz to rpm?
    I have wired my mach3 breakout board to terminals 18 and 20 of P.S. and this turns the spindle on and off from mach3. However it appears to have it running at maximum rpm and as the power supply has to be in auto start mode the knob doesn't work. The software up and down buttons don't change the spindles speed.
    Obviously doing something wrong here. Any ideas? Is it possible for Mach3 to tell the spindle what speed to run at and/or be able to vary the spindle speed from mach3?
    And hopefully last.....
    I bought an external box with an emergency stop button and rpm pot on it.
    I've tried wiring it to the P.S. but they don't appear to work. Once again Danfoss provided some instructions but they didn't work so if you can help me I'm ready to try your ideas.
    Thanks Jase
Page 1 of 19 12311
  1. Huanyang VFD
    By lt00273 in forum Chinese Machines
    Last Post: 09-13-2017, 04:55 AM
  2. Huanyang VFD
    By lt00273 in forum Spindles / VFD
    Last Post: 09-07-2017, 06:10 PM
  3. Huanyang 2.2kW VFD.
    By atc40 in forum DIY CNC Router Table Machines
    Last Post: 10-19-2014, 04:33 PM
  4. Huanyang VFD
    By dwschool in forum Mach Lathe
    Last Post: 02-06-2013, 05:40 PM
  5. Huanyang VFD
    By moonman5 in forum Phase Converters
    Last Post: 01-19-2013, 05:43 AM
