585,973 active members*
4,198 visitors online*
Thread: Drawing Help
    Feb 2010
    Drawing Help
    I need help drawing these Hmmwv doors. The front door is approx 40.5 inches tall and 32.06 inches wide, the problem I have is the bottom 23 inches are flat as a board but when you get to the window it remains perfectly flat but the rest of the door angles back. I dont know how to draw that in solid works 2014. Any advise ?
    I do have a 150 watt laser if some one wants to trade laser cutting for drawings of these doors so I can make a mold that would be great !
    Doug
    Attached Thumbnails Attached Thumbnails 1993-am-general-humvee-m998-hummer-h1-military-x-doors-new-interior-new-paint-13.jpg
    Nov 2017
    83
    Re: Drawing Help
    Think of the door as two parts. The first part is the door panel with the second being the window frame. I would start by doing a sketch of the doors (bend) side view. That will give you the general shape of the door. Then sketch and extrude the window shape and do a sketch/cut to open the door window cuttout. From there it should be fairly straightforward adding the small hinge/handle details and X rib.
    Try and think about how they made the door. From the looks of it the door was a piece of sheetmetal that was bent to shape and then had the window frame welded or riveted in? You could use the Solidworks sheetmetal tools to model it exactly like that as well, but those are a little more advanced.
    Jul 2016
    660
    Re: Drawing Help
    I can draw it for you if you want and post it here for you to download, I just need the exact measurements, I remember in the past years I even draw my own hummer design because im in the process of making custom bumpers for offroad use, Stainless steel material then CNC plasma cut everything then weld it back with a tig weld.
    Attached Thumbnails Attached Thumbnails 12244339_10205163446505340_3564646998614190161_o.jpg
  1. Replies: 1
    Last Post: 04-02-2016, 12:56 AM
  2. new drawing board --wicked size 44x60 drawing area
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 02-08-2015, 12:58 AM
  3. Replies: 13
    Last Post: 10-02-2009, 04:32 AM
  4. jpg,bmp to drawing
    By stk2008 in forum CamBam
    Last Post: 09-30-2009, 11:41 PM
  5. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
