So after many years of having my mill sitting collecting dust,I've finally decided to dig into it. I've been lurking around here for quite awhile reading up and following the builds with great interest,like the Tree 325 retrofit. It has the same sd1525 amps as my lagun and I have the Baldor servos which i beleive are also the same so it's been a nice read so far for sure.
I know that Kanalog likes differential encoder signals,problem is my mill has them but it was only wired for single ended into the cabinet. I'm pretty sure by the looks of the cables on this machine that I'll never be able to run the extra wires required for the extra signals in the original harnesses.
I've been searching and 26LS31 keeps popping up. My question is, if I decide to just put this IC on a board for conversion of signals, will I need to integrate resistors or anything else into it or is it just a simple hook up to the 16 pin IC? Also,is anyone else using this to convert there signal ended encoder signals to differential for Kanalog?
Glen
