585,969 active members*
4,599 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Tool Change Table Position
    Oct 2013
    84
    I need help moving(locating) my table before tool change towards the right front of the machine using machine coordinates (away from the spindle). I have a DATC that moves the tool lower and eventually crashes to the parts itself. Is there a macro/command that i can use to call before M6? I want the Z to move to the highest location then move the XY location before making tool change. Thanks in Advance!!!
    Jan 2015
    417
    Re: Tool Change Table Position
    You could just create a Subroutine to position the Machine and then execute the Tool change, And then get it back where you were with another subroutine if needed.
  1. Park & tool change position after tool probe.
    By Ozzybee57 in forum Mach Mill
    Last Post: 10-16-2016, 03:57 PM
  2. Replies: 2
    Last Post: 12-31-2014, 01:46 PM
  3. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  4. Setting tool offsets and tool change position.
    By trishbits in forum CamBam
    Last Post: 02-08-2013, 12:18 AM
  5. Changing/resetting the table position during a tool change?
    By Jim Ster in forum Mori Seiki Mills
    Last Post: 08-13-2008, 01:31 PM
