585,759 active members*
3,910 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > 2012 Haas VF1 basic 8.1K model, need parameter PAR file
    Sep 2007
    28
    Need to reload Haas VF1 parameter after 3V battery failure.
    System is up running with No alarm,
    Except won't load my original .par file (2012 parameter file format comes with the machine)
    ALL the SETTING is Blank at this moment.
    Setting 7 is Unlocked.
    The current VF1 system has 2015 version up file format.
    VF-1
    Ver M18.23A
    Jan 26, 2015 13.54-55
    Model VF-1
    MOCON 17.08
    Can anyone spare me a copy of their VF1 parameter backup (new model file format if possible)?
    I am willing to give a try whatever I receive, see if works.
    I am assume all the risk.
    One the Phone/Email back and forth with Haas Tech at "Machining Time Savers" Anaheim CA,
    he is not able to send me the new ver. PAR format file for my VF1.
    Haas Tech won't be available to come out after Dec 26, 2017
    Contact me at following,
    pw924 at yahoo dot com
    Thank You very much
    Dec 19, 2017
    Attachment 381840
    Feb 2012
    115
    Re: 2012 Haas VF1 basic 8.1K model, need parameter PAR file
    Can you just hand load them? If you have your old param file it's just text, plus maybe use windows programming calculator for the bits.
    Sep 2007
    28
    Re: 2012 Haas ST10 need parameter file
    Haas Tech show up on Dec 20, 2017
    Reload parameter, problem solved.
    $421.00 for the job
    Sep 2007
    28
    $421.00 for the job (3 hrs approx. reload two Haas machine parameter)
  1. Haas VF-1 2012 High Voltage Transformer
    By Nicklinux in forum Haas Mills
    Last Post: 02-12-2021, 07:02 PM
  2. How to setup basic parameter settings for any vfd
    By djnuwa in forum Spindles / VFD
    Last Post: 05-28-2015, 04:49 PM
  3. Can somebody 3d Print a Solidworks 2012 model for me?
    By twp in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-15-2012, 10:09 PM
  4. Renishaw Probing on a 2012 Haas VM3
    By wincoaw in forum Haas Mills
    Last Post: 09-14-2012, 10:57 PM
  5. Need a basic PLC, suggest a model.
    By keebler303 in forum CNC Machine Related Electronics
    Last Post: 01-28-2010, 04:30 PM
