585,683 active members*
4,888 visitors online*
Results 1 to 6 of 6
    Nov 2017
    TNG and SD card.
    Hi!
    I just finishing the wiring of the SD card holder on my MK3/4 but there is no
    option to save RAW files in the TNG software and if I create file using the old
    version and save it on the SD then nothing happens if I press the start input.
    Is the operation from SD still supported on the TNG?
    Regards,
    Marek
    Mar 2017
    1304
    Re: TNG and SD card.
    Unfortunately SD card does not work with TNG at the moment and its future support is questionable.
    Nov 2017
    Ok I suppose you have your reasons for ditching the SD card support, but if that's so then
    could you consider remapping the three related pins as IO? The MK3/4 has very few of
    those and few extra would be of great help.
    Mar 2017
    1304
    Same connector is used for I2C. I2C is fully supported and you can add virtually unlimited IO pins.
    Nov 2017
    This is great to know but is there a way to use a I2C port expander
    and then use those inputs for controlling functions in the shortcuts
    settings as the regular IO pins?
    Mar 2017
    1304
    Best way for triggering shortcuts in software is with some sort of keyboard emulation. For example something like this:
    Arduino USB HID Keyboard - MitchTech | MitchTech
    (I'm not familiar with this project, I just found this link with google)
  1. Laser cutting service? (For aluminium card the size of a business card)
    By placebo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-11-2012, 01:00 AM
