585,997 active members*
4,990 visitors online*
    Dec 2017
    Haas HRT160 Won't home
    I have a 2011 HRT160 rotary that won't home. We have had a Haas tech in, spent hours on the phone with Haas and no luck.
    What it does when I home it it dose move a very small amount and the give me a 1 second beep. No alarms other than it keeps asking me to home the axis. We can manually move it with the home setting off.
    Here is what has been checked. We have gone through all the parameters and even tried calling it 2 different models. I have checked the wiring for any broken or shorted wires, none. When moving it manually we can get the proximity/home switch to go on and off.
    Seems everyone is stumped and I'm scared to call Haas in again at $130/hr to stand there and change super expensive parts. While investigating this issue they found I had a bad memory chip and that ended up costing almost $8K
    Stephen
    Dec 2017
    Re: Haas HRT160 Won't home
    One more check. I rotated the table 360 and as per the distance moved on the screen it says 220deg.
    Jan 2004
    539
    One more simple check is you said "and even tried calling it 2 different models"
    I had this one get me once, when you look at the page of available models there is a "next page" or drop down..don't remember but there are more than you see at first glance.
    I would try them all no matter what the description says.
    Gary
    Nov 2006
    490
    On that era of machine (2011) doesn't the beep mean the door locks are disengaged? That's what my 2012 does.
    It sounds like a software issue. Did the technician perform a factory reset on the control? (the one where you wipe all the parameters?)
    The angle mismatch problem is common when you select the incorrect model rotary hardware since the gear ratio is different (so the encoder doesn't match up to the physical movement). It definitely sounds like there's a weird parameter going on...
  1. How to indicate a HRT160 rotary indexer
    By veets1 in forum Haas Mills
    Last Post: 07-03-2014, 01:43 AM
  2. HRT160 Can't home
    By JohnJW in forum Haas Mills
    Last Post: 09-17-2013, 03:37 PM
  3. MiniMill 2 with an HRT160
    By obiwon in forum Haas Mills
    Last Post: 03-10-2012, 01:32 PM
  4. HRT160 3 jaw chuck? Tooling bar?
    By helocat in forum Haas Mills
    Last Post: 01-11-2012, 07:03 AM
  5. HRT160 Missing parameters
    By richmond1992 in forum Haas Mills
    Last Post: 11-21-2011, 05:11 PM
