585,877 active members*
3,315 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > question about Breakout board for Laser Cutter
    Mar 2012
    27
    I'm to the stage of installing the breakout board for my laser cutter and I'm somewhat overwhelmed by all the choices... Anyone have specific recommendations?
    Doe anyone have experience with this BOB? https://www.ebay.com/itm/3-Axis-CNC-....c100010.m2109
    Nov 2008
    644
    Re: question about Breakout board for Laser Cutter
    These Mach3 bobs are really designed for routers with a spindle. So in Mach3 you turn the spindle on and control the speed. The PWM pin could control the power level of a laser but Mach3 isn’t designed to quickly cycle it. There are ways to turn this signal on-off outside of Mach3 but its all more technical and limited. Double the cost of this BOB will get you a DSP laser controller. I’d consider that route.
  1. breakout board question
    By 1hander in forum CNC4PC
    Last Post: 03-12-2017, 05:59 PM
  2. breakout board question
    By gurasha in forum Stepper Motors / Drives
    Last Post: 05-09-2013, 05:41 AM
  3. breakout board 200khz option question
    By h_2_o in forum CNC Machine Related Electronics
    Last Post: 04-01-2006, 10:52 AM
  4. Question PMinMo Breakout Board
    By huckshooter in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-21-2005, 03:46 PM
