585,978 active members*
4,438 visitors online*
    Oct 2017
    18
    KFLOP Not responding
    Houston we have a problem!
    So far the board work fine.
    My today job:
    1) Activate the VCP in “Properties” – “Advanced” – “Load VCP” (Virtual Com Port)
    2) Reboot the PC
    3) Install driver for new KFLOP - USB Serial Port
    4) Instal Tera Term software for serial communication
    5) open it and configure KFLOP Port (9600)
    6) Try some command: Version, Reboot! All command work fine...
    but...
    from now on the KMotion software it no longer worked!
    Apperar two little windows :
    KMotion present but not responding - Correct problem and restart application
    or
    Can't connect to KMotion Board #0
    I try several things:
    1) Reinstalled new drivers, for KFLOP USB and KFLOP Serial (COM)
    2) Reinstalled KMotion Software 4.33 and then 4.34
    3) Reinstalled the board on another PC
    4) Extreme and last resort: RECOVERY (firmware)
    No method worked!
    KMotionCNC or KMotion don't work
    But the strange thing is that Tera Term on KFLOP serial Port still work!! (type Version, Reboot! or other command these work!)
    May 2006
    4045
    Re: KFLOP Not responding
    Hi CNCtronic,
    Very strange.
    If Tera Term with serial Port works then that indicates KFLOP is working correctly and the problem must be on the PC. KFLOP doesn't know if command strings are sent via the PC Serial Port Driver or the DLL Driver.
    But you said you re-installed the drivers. Maybe you didn't do it correctly or you didn't remove the other drivers?
    What shows up in Device Manager?
    What OS are you using?
    Odd that you were able to do Recovery if KMotion doesn't connect.
    Regards
    TK
    http://dynomotion.com
    Mar 2015
    5
    Hello!
    Did you find the solution? i'm with the same problem!
    Thanks!
    May 2006
    4045
    Hi Gabriel,
    I see you posted on our forum that Flash Recovery solved your problem.
    TK
  1. MK1 software not responding
    By adidoro in forum PlanetCNC
    Last Post: 08-03-2017, 07:35 PM
  2. VFD not responding
    By SwampDonkey in forum Tormach Personal CNC Mill
    Last Post: 10-21-2014, 03:13 PM
  3. Jog no longer responding
    By roundrocktom in forum Mach Software (ArtSoft software)
    Last Post: 01-20-2013, 06:19 PM
  4. Vfd Not responding.
    By Katoh in forum CNC Machine Related Electronics
    Last Post: 01-20-2013, 09:01 AM
  5. CNCsimulator not responding?
    By Al_The_Man in forum G-Code Programing
    Last Post: 12-21-2012, 12:50 PM
