586,011 active members*
5,013 visitors online*
Results 1 to 10 of 10
    Apr 2012
    161
    Dropbox Unresponsive
    I just installed PP2 and am trying to get Dropbox going. After you login you get a browser page, but I keep getting page unresponsive errors from the Chrome browser. I have a good internet connection.
    "You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
    Apr 2012
    161
    Re: Dropbox Unresponsive
    From the dropbox app, I'm getting dropbox unresponsive errors. I don't know what Tormach did for the dropbox implementation, but so far it's terrible. I've entered the folders I want excluded, but Dropbox is syncing them anyway.
    Apr 2012
    161
    I went into Linux GUI and installed dropbox from terminal:
    sudo apt-get update
    sudo apt-get install dropbox
    Seems to have worked okay. I noticed while I was in the Linux GUI that the Chrome browser was very slow, basically unusable. Even just trying to change tabs was very slow, let alone pages displaying.
    Doing it this way I got the normal DropBox config window and it's easy to deselect folders to sync. Maybe Tormach doesn't want it installed this way for reliability reasons, I'll see if it causes a problem with PP 2.
    --Scott
    Jul 2017
    70
    I'd guess memory constraints are impacting your responsiveness. 1 GB controllers are a bit tight for the new 64-bit linux kernel + PathPilot + Chrome tabs + Dropbox daemons (esp. if you have a large Dropbox account).
    I found the 2.0.0 release notes mention a new ADMIN MEMORY command - looks like it tells you how much memory is on your system on the Status page.
    Quote Originally Posted by scott216 View Post
    sudo apt-get update
    --Scott
    Apr 2012
    161
    Thanks. I'll have to give the memory command a try.
    Aug 2009
    294
    Forgive my ignorance, but I've always wondered why Dropbox was used in this new version of PathPilot. If the controller can see Dropbox, then it must be on a local network. Can't the controller see directories on this network instead of having to use Dropbox?
    Apr 2013
    1788
    Yep. I've been connecting to a network share since the beta for PP. A free Microsoft utility, robocopy, provides quick sync of any changed files.
    Apr 2012
    161
    Quote Originally Posted by kstrauss View Post
    Could you give more detail about how you set this up?
    Jun 2005
    656
    Likewise, I just post G code straight to the Tormach share drive. The Tormach is otherwise firewalled off from the internet.
    Apr 2013
    1788
    I setup a new share on the control computer that points to the \operator directory on the control machine so that I have access to all useful LinuxCNC files.
    XPS9100 is my CAD/CAM machine. I run the following .CMD file (via an icon on the desktop) on my workshop machine whenever I finish editing and posting the gcode. All files on the workshop machine are synced with the office machine and then files on the Tormach control computer are synced from the workshop machine. That means that I have three copies of everything on machines in two buildings.
    net use y: \\pcnc770\operator
    c:\drawings\robocopy \\xps9100\drawings c:\drawings /r:0 /s /e /purge
    c:\drawings\robocopy c:\drawings y:\gcode\drawings /r:0 /s /e /purge
    See https://pureinfotech.com/how-to-use-...ool-microsoft/ or use Google to find more on robocopy.
  1. DROPBOX warning
    By dannirr in forum Tormach PathPilot™
    Last Post: 12-28-2017, 12:20 AM
  2. Stepper motors unresponsive
    By bk5629 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-03-2017, 11:53 PM
  3. PathPilot and Dropbox
    By KSky in forum Tormach PathPilot™
    Last Post: 02-13-2017, 04:18 AM
  4. TB6560 Completely Locked Up and Unresponsive
    By ajbeck in forum Stepper Motors / Drives
    Last Post: 08-25-2013, 11:29 PM
  5. T1 control and unresponsive parameters
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-21-2007, 08:52 PM
