hi evry one i have 4 of lichuan closed loop https://www.aliexpress.com/store/pro...5bdadf473tkD2E
can you help me for chose the right power supply?
and how to work with this https://www.aliexpress.com/item/debu...86dcea5a&tpp=1
Something like this would be a good solution>
PS-15N80 - 1500W 80V Power Supply - AnTek Products Corp
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
80v isn't too much
and how much Amps for all 4?
the one consume 7.5Amps
The amperage requirement would be 2/3 of the total amp draw of the combined motors.
I would email the manufacture and confirm the suggested optimal power supply voltage.
Higher voltage will enhance the r.p.m. range of the motor.
Jeff...
what about this power supply https://www.omc-stepperonline.com/po...-s-350-60.html
i will use 4 of theme one for eatch stepper
am i right?
can i use normale AC transfomer (48v 5.22A 250VA) for this cosed loop driverhttp://www.cnczone.com/forums/attach...d=383122&stc=1?
http://www.cnczone.com/forums/attach...d=383116&stc=1http://www.cnczone.com/forums/attach...d=383120&stc=1http://www.cnczone.com/forums/attach...d=383118&stc=1
Yes
is it safe or not?
explain to me pls
An ac power source "20~70VAC" is the stated manufacturer's specification 48 VAC is safe.
hi Jeff i'm sorry i have lot of questions for you would help me
I have 2 of 36V 10A power supply. can i connect them to have 72V 10A power supply like that
http://www.cnczone.com/forums/attach...d=383284&stc=1
Be extremely cautious connecting the power supplies in series since they are switching power supplies, many times they will not play well together.
The capacitors inside the power supplies most likely are not rated anywhere near 70 volts.
The electrolytic capacitors can explode violently if the operating voltage is exceeded!
Also If the commons of the power supplies are at ground potential it will not work.
I would not recommend doing so without a good understanding of such matters.
Jeff...
