584,805 active members*
5,153 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > V Carve Pro unwanted ramps on slots
Results 1 to 10 of 10
    Sep 2017
    33
    Hi
    Im having trouble cutting slots in V Carve pro.
    When I cut a simple L shaped slot, it plunges ok, but when it gets to the end, instead of leaving the slot squarely upwards, it ramps on exit
    I'm using the 'Profile Toolpath' option to cut the slot with a 6mm mill bit. I can see no option to adjust this.
    How do I get it to leave the cut slot with out ramping up?
    Re: V Carve Pro unwanted ramps on slots
    Is the ramp actually in the g-code, or is your controller causing the ramp?
    Sep 2017
    33
    I'm not sure. From the 3D preview it looks like its cutting normal. There doesn't seem to be an option in v-carve tool path options for anything which would cause it as its all greyed out as the slot is a simple procedure.
    In 'Toolpath Options', is 'Profile toolpath' (the 1st option) the correct one to use for this type of cut?
    My guess is that your controller is doing it. What are you controlling the machine with?
    Sep 2017
    33
    I have MACH3 running on laptop, I'm not sure what the controller box is called. Everything else is running fine. It cuts voids, shapes spot on. But on a one way a - b slot, it ramps as it leaves the slot. (not stop and go upwards motion).
    What is your Z axis acceleration set to in Mach3? Increasing it will probably fix the issue.
    Sep 2017
    33
    Here are the Z Axis settings and final G-Code:
    Go into Config >General Config, and check the box "Stop CV on angles>" and set it to 89.
    Sep 2017
    33
    Thanks. I'll give that a try tomorrow. Does the info I provided suggest that will work?
    Sep 2017
    33
    Thank you very much.
    Problem sorted!
  1. 1.5W Laser on RAMPS 1.4
    By canteen234 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-31-2016, 02:06 AM
  2. zen toolworks cnc with ramps v1.4
    By journeyp in forum Zen Toolworks
    Last Post: 10-07-2015, 07:42 PM
  3. Ramps 1.4 vs Ramps 1.5.7
    By dregalia in forum DeskCNC Controller Board
    Last Post: 11-06-2014, 10:52 PM
  4. multipurpose ramps drivers
    By fadedwriter in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-18-2013, 06:02 AM
  5. cut ramps
    By guido_kp in forum Autodesk
    Last Post: 04-09-2007, 02:34 AM
