585,977 active members*
4,670 visitors online*
    Mar 2005
    137
    Kflop/Kanalog/Mach3 setup motor how to ?
    Hi guys,
    got a newbie question here, i've install mach 3 then the kflop plugin on top.
    i've setup the wiring with the encoder -A +A -B +B on the kanalog. when i move the motor i see the number change in kmotion, so that good.
    i ve got 2 questions:
    1- for my servo amplifier my connection goes 1- analog sheild signal 2- Analog differential + (plus) 3- Analog differential - (minus)
    so do i take the kanalog +/-10V to the 2-analog differential + (plus) and the kanalog gnd to the 3-analog differential (minus)
    2- how do i calibrate the motor in with kmotion ? i didn't know where to go ? do i go into config/flash ? or do i calibrate in mach 3 directly.
    oh i was able to get the version send via kmotion so i'm doing something right.
    thanks for the help guys first time with kflop /kanalog Attachment 382544
    Mar 2005
    137
    Re: Kflop/Kanalog/Mach3 setup motor how to ?
    note to self found config for step on youtube: https://www.youtube.com/watch?v=pW-9fDLAn2s
    search to see if they have one with mach3 and kanalog integration.
    May 2006
    4045
    Hi k-linkz,
    yes
    First get everything configured, tested, and tuned in KMotion.exe using encoder counts before running Mach3. Then set your system resolution in the Mach3 Motor Tuning. See the wiki:
    Dynomotion
    You might also read some initial testing and tuning steps here:
    Kanalog Hardware Info - Dynomotion
    Regards
    TK
    http://dynomotion.com
    Mar 2005
    137
    Quote Originally Posted by TomKerekes View Post
    Hi k-linkz,
    yes
    Dynomotion
    Regards
    Thanks Tom.
  1. kanalog+kflop+amplifier setup question
    By k-linkz in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-23-2017, 07:10 PM
  2. Buffer starvation error with Mach3+Kflop/Kanalog
    By mitzpetel in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-01-2015, 03:27 PM
  3. KFlop/Kanalog/Mach3
    By keithkyll in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-12-2014, 03:32 AM
  4. Kflop - Kanalog setup guide.
    Last Post: 07-27-2013, 05:42 PM
  5. CNC upgrade with Kflop/Kanalog/mach3
    By Frank_W in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-26-2013, 01:04 PM
