585,665 active members*
3,208 visitors online*
    Mar 2007
    Bystronic Laser
    We have a Bystronic laser that is causing us problems,
    With have a vacum leak somewhere and unable to find.
    Both Heat exchangers have beeen sent away and checked all glas ware has been removed and replaced, however under advise we brought in a hand held Hellium sniffer unit and pump Hellium into the system instead of nitrogen so to locates any leaks.
    we did identify possible problem areas and fixed. However we are still losing pressure approx 12/14 m/bar per minute with the result being loss off power.
    Has anyone else experienced this and how did they overcome the problem?
    Oct 2005
    96
    I believe there is a service centre in the UK for bystronic.
    If you fails to check the fault after many attempts it is better to call the service center.
    Have you check all the laser gas tubing for the incoming and outgoing together with the valve block.- My guess that you never check these items.
    Mar 2007
    Yes i know agent for Bystronicand yes have checked tubes for leaks(see information posted) we are looking at £200000 + machine here with a 2.5Kw laser.
    Please give me some credit or useful information before replying
    Oct 2005
    96
    Sorry to have you misunderstood what i have meant.
    The tubing i refer to is the copper pipes and also the plastics pipes and not the Glass tubes on the resonator.
    After some period of time the plastic tube might have miniture crack on it due to ageing. I have come across this type of problem many times before .
    If there is some plastic connector on the gas line have this check also, same issue of miniture cracks also.
    Of course i know that this is a industrial laser and should be a RF laser if i am not wrong.
    Feb 2012
    what type of bystronic are you working with.
  1. Bystronic
    By COCO in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-28-2012, 01:52 PM
  2. Converting a laser printer into a 3d laser printer
    By João Carimo in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2011, 09:56 PM
  3. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-13-2007, 08:39 PM
  4. Is this laser big enough?.. :)
    By hotponyshoes in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-28-2007, 08:04 PM
  5. example laser cut
    By owhite in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-22-2005, 10:24 PM
