585,981 active members*
4,226 visitors online*
Results 1 to 10 of 10
    Jan 2017
    17
    Syntec 6mb tool change alarm mlc 76
    *12:10 AM Today
    Hi*
    I have syntec 6mb controller, cannot run tool change in program or MDI.
    I get mlc 76 alarm R44.11.
    Tool change start and hang just before tool release then i get the alarm.
    Please help
    Sent from my SM-G920F using Tapatalk
    Jun 2005
    1730
    Re: Syntec 6mb tool change alarm mlc 76
    Check your air pressure and test using a manual release
    Jan 2017
    17
    Quote Originally Posted by CNCMAN172 View Post
    Manual release work fine, all other pneumatic actuators also work like dust hood and alignment pins..
    Jan 2017
    17
    Also carrosel tools tray moves and clips on the tool but there is no tool release.
    Sep 2012
    228
    Hey Bascil,
    See. the thing about alarms is that Each Syntec Controlled machine is customized and configured by the Machine maker...
    Sadly, they never seem to bother to update the alarm descriptions, or provide detailed parameter lists, etc..
    I can only suspect that a sensor, or expected action is not happening...
    Is this a new problem?
    Did the machine work fine before?
    Jan 2017
    17
    Quote Originally Posted by Frankmali17 View Post
    Hey Bascil,
    Its a new machine, the tool change worked few times with MDI then stopped working.
    Jan 2017
    17
    Hey Bascil,
    Solved it my friend, a sensor on the tray actuator was loose and a little off, adjusted .. works fine now. Thanks for your reply
    Aug 2017
    5
    hi everybody can anyone help me with my machine error
    Attached Thumbnails Attached Thumbnails 32160000_1928382680514525_2113096649474572288_n.jpg   32130708_1928382870514506_6476917012873347072_n.jpg   32203036_1928382837181176_7248455656502460416_n.jpg
    Sep 2012
    228
    I think you need to look up manuals or data.. or a phone contact, for the mitsubishi Driver.. and see what AL90 is as far as the Servo Driver is concerned..
    Aug 2017
    5
    THANK YOU FRANK MAIL,
    i already look on the manuals but there is no clear instructions on how to fix the alarm. do you have steps in removing the alarm.
    appreciate your help.
    thanks
  1. Replies: 14
    Last Post: 10-09-2017, 03:37 AM
  2. help with Post processor for syntec with manual tool change
    By redvanth in forum Chinese Machines
    Last Post: 10-18-2016, 06:39 PM
  3. help with PP for Syntec Manuela tool change
    By redvanth in forum Post Processors
    Last Post: 08-27-2011, 01:20 PM
  4. Tool change alarm?
    By Claytonc in forum Maintenance DIY Discussion
    Last Post: 06-23-2011, 02:55 AM
