585,737 active members*
4,818 visitors online*
IndustryArena Forum > CAM Software > CamWorks > CAMworks Post for a Brother Tapping Center - anybody got one?
    Dec 2016
    I am new to CAMworks and I have a Brother TC-S2A. I have been working on getting a post going for my machine and much of it is working. I am stuck at the rigid tapping command that the Brother uses. It uses a G77 code which is no problem I have my post spitting this out and most of the parameters it needs are correct. Where I am stuck is with the thread pitch parameter. It needs a J parameter where for a 20 thread per inch tap it would be J20 or for a m3x0.5 tap it would be J50.8 (50.8 threads per inch). The tool crib has tap thead pitch stored in inches per thread so I would need the reciprocal of this. I think it is doable but I can't figure it out. I actually have Solidworks CAM, which is CAMworks, but this seems to be new to all the Solidworks tech service people so an answer is sort of slow coming through that route. Any ideas?
    May 2010
    307
    Re: CAMworks Post for a Brother Tapping Center - anybody got one?
    Do you have the .src and .lib files available? The post can be edited to match your needs if you have those files.
    Sent from my XT1575 using Tapatalk
    Dec 2016
    Quote Originally Posted by giz View Post
    I do have them. Who can make these mods? My email is petedeal1(at)yahoo(dot)com
  1. Brother Tapping center TC-225 - Fanuc NC
    By VladT in forum CNC Machining Centers
    Last Post: 08-09-2017, 11:44 AM
  2. used brother tapping center
    By dec11ad in forum Uncategorised MetalWorking Machines
    Last Post: 10-17-2014, 05:04 PM
  3. Brother 32B QT Tapping Center problem
    By Jim Beyer in forum Uncategorised MetalWorking Machines
    Last Post: 10-04-2012, 02:17 AM
  4. Weird problem with Brother tapping center
    By zukimaniac in forum CNC Machining Centers
    Last Post: 02-04-2011, 02:38 AM
  5. brother TC-20A CNC Tapping center
    By louis14 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-08-2006, 12:29 AM
