585,898 active members*
5,285 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > INDRAMAT TDM-3.2 _Enable Problem!
Results 1 to 2 of 2
    Jul 2016
    108
    Hi there :-)
    I'm working on a Gildemeister GAC65 lathe, and I have a problem with one of my axis Servo Drive " TDM 3.2-20-300-W0".
    I connect power, and truth give feed command with my multimeter to E1, E2 (Command Pins), there are· no response.
    Well. after changing the +&- Poles, motors shaft runs a little and BS Alarm LED turning on, the drive goes to disable mode.
    I try to fix this problem with hardware test, but it seems ok, What you think, where I have to Check?
    any help will kindly appreciated.
    With Regards
    Attached Thumbnails Attached Thumbnails photo_2017-12-30_18-51-46.jpg   photo_2017-12-30_18-51-40.jpg
    Jul 2016
    108
    Re: INDRAMAT TDM-3.2 _Enable Problem!
    Hi there :-D
    I make solve the problem, Some Capacitors Didn't works well.
    Regards
  1. M-parametrs Indramat 2AD
    By Smouk in forum Controller & Computer Solutions
    Last Post: 04-04-2018, 02:10 PM
  2. Indramat TVR 3.1-W015-03
    By richmmm in forum Servo Motors / Drives
    Last Post: 11-01-2017, 02:10 PM
  3. indramat parts
    By mikemcg in forum Uncategorised MetalWorking Machines
    Last Post: 07-12-2012, 08:08 PM
  4. Indramat
    By xclr82xtc in forum Servo Motors / Drives
    Last Post: 10-10-2010, 08:00 AM
  5. Indramat software
    By bigfoot in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-21-2009, 04:52 PM
