Hi; I've been retrofitting a Fanuc 6MB based VMC with modern electronics. I used the Pico PPMC board set (Jon from Pico has been unbelievable with support) and LinuxCNC. It's going great.
My question is about feeding the existing Fanuc spindle controller (A06B-6044-H007) with the 0-10V control voltage. My Pico DAC "stalls out" at ~2.0V of supply. If I unhook the DAC from the spindle controller, it outputs 0-10V just fine but can't get above 2.0V when connected. If I feed the controller with an external linear power supply, everything works great. Speed goes up and down correctly with 0-10V.
My assumption is that the Spindle controller needs more than the ~20mA the DAC will supply.
I'll measure the actual current used in each case.
Has anyone encountered a similar problem?
