Bad vfd. Need new HItachi drive. Spindle alignment parts.
Thanks brother. Any chance your good with Hitachi vfd parameters?
Thanks. I sent the bat signal out to Sportybob.
Hi All, talking to Plane Cap'n He is using the SJ700 drive. These drives do not do the orient correctly, The parameters are there for the creep but it does not work correctly. This drive wants you to have the "orient" option board and would require additional spindle encoder feed back, YUK, YUK and more YUK. (14 calls to Hitachi engineering to get that figured out)
He is going to get a new drive ( WJ200) and I will get him thru the parameters.
My drives I provide the install, wiring and parameter documentation and all the tech support you need. Mon - Sat 7:30am to about 9 PM,
sportybob
