585,578 active members*
4,079 visitors online*
Results 1 to 9 of 9
    Dec 2017
    8
    Brand New Mini Mill
    Hi guys,
    New to the forum and just bought a brand new Haas Mini Mill. Had a couple of questions that maybe someone would be kind enough to answer. Does the power cable wire directly into a 40amp breaker box? Or does it plug into a 40amp receptacle that is wired into your main panel? I am putting the Mill in my garage at home.
    Dec 2013
    5717
    Re: Brand New Mini Mill
    You could do it either way. I have two machines wired direct with no disconnect on the wall, another plugs in, and two others are wired in with disconnects on the wall near the machine.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2017
    8
    Jim, Thanks for the reply. I have seen some with plugged cables and some wired. Its a mazing to me that Haas does not have a definitive way of wiring for power.
    Jun 2004
    6618
    Right, either way.
    I have mine wired into a plug because my plasma cutter shares the outlet and I can only run one at a time.
    Lee
    Dec 2017
    8
    Thanks man
    Jun 2004
    6618
    I think larger machines need their own sub-panel.
    You probably need to be able to lock out tag out.
    Lee
    Dec 2017
    8
    I was thinking of installing a sub panel anyway. Sick of unplugging stuff. I just ordered the machine Haas says 12 weeks to delivery. Would you happen to know if they are early or late on their delivery times?
    Jun 2004
    6618
    They estimated my lead time at 4 to 5 weeks and it arrived exactly 5 weeks later.
    Pretty accurate that time.
    Lee
    Nov 2012
    145
    Quote Originally Posted by Bubba73 View Post
    Hi guys,
    I wired my TM1P from the breaker box to a interupter switch at the machine so that if it needs to be locked out for any reason the sparky working on it won't have that certain glow! If you look in the instilation literature it will tell you all that information you need to know.
  1. Brand New 220V Mini-60 40W for sale!
    By Nolan Yang in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-26-2015, 08:04 AM
  2. Homemade Mini Press Drill Convert Your Dremel Into A Mini Mill
    By doitbymyhand in forum Wood Lathes / Mills
    Last Post: 07-05-2015, 04:41 PM
  3. Super Mini Mill 2 vs Mini Mill Tool Tracking
    By Terry G in forum Haas Mills
    Last Post: 05-25-2014, 06:55 AM
