584,812 active members*
5,228 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas parametric programming (floating point) help
Results 1 to 13 of 13
    Jan 2018
    7
    Question Haas parametric programming (floating point) help
    I am building a macro (to run on a CHC) to log serial numbers and operator IDs for later database query at a relatively large foundry.
    Our Serial format is nonconsecutive as follows
    123A
    I am using a line of code to concatenate several (manual) operator entries into a single string where:
    #500-#503 are numerical digits
    #504 is an alpha character
    #805 is the numerical translation of the serial number
    #805=[[ROUND[[[[#500-48]*100]+[[#501-48]*10]+[#502-48]+[[#503-64]/100]]*100]]/100]
    The trouble that I am having is that the final digit, which should always read in increments of 0.01 is plagued with what appears to be a floating point error. The effort towards placing the numerical value and the alpha value into a single variable is in hopes that the operator can verify the value and reenter as necessary.
    This seems to be an extremely simple task, but I've put the above line together numerous ways, always to be plagued with a similar error.
    Any suggestions?
    Feb 2012
    115
    Re: Haas parametric programming (floating point) help
    Do you have any computer programming experience? You need to separate all those into steps and figure out where it goes wrong. It could be an overflow somewhere. Also, floating point loses precision with large numbers as well.
    Jan 2018
    7
    I don't have any programming experience beyond g code and very basic PLC work.
    I do know, however, that the error originates in the
    [[#503-64]/100] operation
    Sent from my Pixel 2 using Tapatalk
    Feb 2012
    115
    Do you know the approximate values before and after for that step? And what is the desired value?
    Jan 2018
    7
    The value changes based upon operator inputs.
    Typically the numerical portion is less than 200, and the alpha input is A, B, C or D.
    If I am understanding your previous response correctly, you are suggesting g that I concatenate at
    VALUE * 10^N
    and in a separate operation, divide by 10^(N+2) in order to restore the desired decimal location.
    In this case, doe Haas treat division and multiplication by less than one on the same way?
    Feb 2012
    115
    What I am trying to say is that it isn't really a haas limitation, but rather likely the a math float type limitation. You need to figure out where and why this happens and reformulate your formula. That's why I suggest splitting it all out into single steps, that way you can single step through your code and watch the actual values as it gets calculated in the macro param window.
    Feb 2012
    115
    I don't understand what you are doing well enough to give ideas. I do think there is a pow option in the macros though.
    Jan 2018
    7
    Sorry, pow option?
    Feb 2012
    115
    Power
    Feb 2012
    115
    What is your desired output, anyway? Also, I think you perhaps said wrong, #503 = the alphanumeric. If I understand your problem you want the alpha to be the decimal.
    Perhaps
    #805=[[#500-48]*100]+[[#501-48]*10]+[#502-48]+[[#503-64]/100]
    I think this would output
    123.01 for 123A
    123.26 for 123Z
    Jan 2018
    7
    Quote Originally Posted by erikfriesen View Post
    Perhaps
    123.01 for 123A
    123.26 for 123Z
    This is absolutely correct, however, the value returned is
    123.01 for 123A but
    123.01999999... for 123B
    I will try your specific line shortly as well as the FUP operator.
    Feb 2012
    115
    Ok, Perhaps round on the last? the .01999 is definitely caused by floating point math, unfortunately. You could try something like [[[#503-64]+0.00001]/100] or ROUND[[#503-64]/100]
    Nov 2006
    490
    What about the "FIX" macro command? If I remember correctly that will dump out the trailing remainder numbers and give you a value that has been "rounded down". I never used it outside of the probing macros though, so it may not do what you need...
  1. Replies: 5
    Last Post: 09-25-2013, 05:20 PM
  2. Xilog 3 Parametric Programming Offline Programming
    By julioykaly in forum Commercial CNC Wood Routers
    Last Post: 04-27-2013, 09:22 PM
  3. G-code and floating point numbers?
    By donek in forum G-Code Programing
    Last Post: 09-27-2012, 08:05 AM
  4. new to parametric programming
    By dougdownunder in forum Commercial CNC Wood Routers
    Last Post: 04-24-2012, 08:48 PM
  5. Parametric Programming
    By gene rhodes in forum Parametric Programing
    Last Post: 07-26-2010, 10:32 AM
