585,758 active members*
4,675 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Want to force post to generate R instead of I,J
Results 1 to 3 of 3
    Aug 2009
    22
    I'm having trouble with BOBCAD generating a G2 or G3 inputting I0 and J0 in code lines. I have a Haas VF2 Using BC V24. The program is small engraving with intricate moves. I'm guessing I can make a change in the post, but don't know what line. I have given 1st few lines of code if that would help to understand my problem. The problem line has been separated out. This is just a sample section, there are hundreds more lines with I0, J0. Thanks for the help
    T01 M06
    G00 G90 G54 X.3817 Y-.5304
    S10000 M03
    G43 H01 Z.1 M08
    G01 Z-.003 F48.
    G02 X.296 Y-.526 I-.032 J.2099 F80.
    X.2503 Y-.5073 I.047 J.1799
    X.2146 Y-.479 I.077 J.134
    G00 Z.1
    X.2503 Y-.5073
    X.3218 Y-.3939
    G01 Z-.003 F48.
    ******* G03 X.2504 Y-.5109 I0. J0. F80.********
    X.2691 Y-.5206 I.0811 J.133
    X.3075 Y-.5326 I.0732 J.1671
    X.38 Y-.5355 I.0461 J.2377
    G01 X.3886 Y-.5344
    Dec 2011
    295
    Re: Want to force post to generate R instead of I,J
    Quote Originally Posted by BigC View Post
    T01 M06
    S10000 M03
    G43 H01 Z.1 M08
    G01 Z-.003 F48.
    G00 Z.1ss
    X.2503 Y-.5073
    X.3218 Y-.3939
    G01 Z-.003 F48.
    G01 X.3886 Y-.5344
    Line 222 in post
    Arc crnter A= absolute b=incremental d =unsigned e =radius
    Jul 2008
    70
    26. Set debug comments for post editing
    debug_ON
    use that turn it off safe post, post out your code and you can see were stuff is at.make sure to copy post before you make any changes.
  1. generate CNC code
    By stehno731 in forum Alphacam
    Last Post: 04-07-2017, 12:45 PM
  2. please, help to generate teeth :)
    By deadlykitten in forum Solidworks
    Last Post: 06-06-2016, 07:56 PM
  3. How I generate post in metric not inch
    By claudiu220405 in forum GibbsCAM
    Last Post: 04-28-2014, 01:47 PM
  4. Replies: 17
    Last Post: 02-23-2014, 04:21 AM
  5. Generate NC option
    By Doug W in forum Hypermill
    Last Post: 01-15-2008, 04:32 AM
