585,877 active members*
3,075 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > Emcotronic T1 Control (Need Help )
Results 1 to 6 of 6
    Jul 2009
    6
    Hello everyone.
    Is there anyone who could help me with Emcotronic t1 cnc control.
    I have solved this RS-232 problem and machine works now, but i like to ask help with tool measurements.
    I have set parameters that machine should be able to take measurements with scratching trial workpiece with known dimensions.
    I would like to know prosedure how to take care of this measuring??
    Regards:Tatu
    Mar 2016
    324
    Re: Emcotronic T1 Control (Need Help )
    U need to push TO button (Shift+T) and go to the field U want to change (Tool number and measuring direction) and push enter.
    here's the manual:
    http://www.kfilipowicz.zut.edu.pl/Pr...structions.pdf
    Jul 2009
    6
    Quote Originally Posted by steryd View Post
    here's the manual:
    Hi
    Thanks for your response.
    Is it too much to ask for more accurate instructions? I have tried this but not succseed.
    When i hit shift+t the led start blinking and display show also x or z blinking.
    What i have to do after this.
    Maybe i'm stuptd, but not succseed yet
    Mar 2016
    324
    You should see tool offset list.
    Otherwise It can be like in T2 -You should input the offset number (1-12) and then push enter.
    it will input the values to offset number You wil indicate. But anyhow there should be offset list visible.
    Jul 2009
    6
    Hi
    I have set this parameter high ( L0 bit 4 Tool Measuring 0 0,16 Tool measuring with reference workpiece for T1 )
    i think that controller should be capable to automatically calculate values to compensation?
    maybe i have still some parameters missing or i'm doing it wrong.
    Mar 2016
    324
    in that case U need to first measure the T1 tool as reference. (it should be in 1 station of the mag.)
    Then go manually to the required height
    push shift->T->number (01this case) ->enter
    This should store the value.
    Im not sure if U wouldn't need to set zero length once for reference (the same procedure but for T00 with empty spindleod some short thing in it) if the machine was out of power for long time.
    I don't have any working emco now so i have to recall it in my memory.
  1. Need Emcotronic code
    By smoregrava in forum Controller & Computer Solutions
    Last Post: 01-04-2021, 07:27 PM
  2. EMCOtronic TM02 F1P-CNC
    By BosseP in forum EMCO CNC Machines
    Last Post: 04-19-2018, 05:45 AM
  3. Emcotronic TM02
    By stefannils in forum Want To Buy...Need help!
    Last Post: 01-05-2018, 11:21 AM
  4. Emcotronic M1 all you need to know
    By smoregrava in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-28-2017, 12:38 PM
  5. Question about the Emcotronic TM02 control
    By tspoon20 in forum CNC Machine Related Electronics
    Last Post: 08-13-2015, 02:39 AM
