585,717 active members*
4,034 visitors online*
Results 1 to 5 of 5
    Mar 2011
    RuiDa RDC6442G X and Y out of limits
    I tried to find a solution before make the post but nothing.
    So my dsp controler display X 10000 and Y 10000
    As you uderstand when I turn it on the head moves to upper right and hits.
    I do not know how to put it back to correct settings.
    My laser is 100W 900x600
    Jan 2008
    940
    Re: RuiDa RDC6442G X and Y out of limits
    Is your homing turned on
    Mar 2011
    yes both of themand I checked them on the dsop and the voltage is correct also.
    Somehow the laser thinks that has a table 10m x 10m
    May 2017
    i have the same problem. Do you fixed?
    Hello
    I have the same problem.did you fix it ?
    Maybe you can tell me solution for it !?
    Best regards
    QUOTE=tonylgn;2135134]I tried to find a solution before make the post but nothing.
    Thanks[/QUOTE]
  1. Ruida RDC6442G LED 14 Blinking and laser will not fire
    By s1nth3sys in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-04-2023, 01:17 PM
  2. Information about RuiDa RDC6442G
    By Labmaster in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2020, 06:56 PM
  3. What is the difference between a Ruida RDC6332G and RDC6442G controller?
    By AdrianPage in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-07-2018, 05:42 PM
  4. Ruida RDC6442G problem
    By sanyyos in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-24-2017, 08:01 AM
  5. What is better? Leetro 6585, Anywells AWC798C, or RuiDa RDC6442G
    By customquint in forum Laser Control Software
    Last Post: 03-10-2017, 02:10 AM
