585,760 active members*
3,844 visitors online*
Results 1 to 14 of 14
    Dec 2007
    578
    Pop Up Reminder
    Tom,
    I decided to move this topic from yahoo group. Maybe someone else might be able to use it. And having it on CNC Zone makes it easier.
    Original post from Yahoo Group.....
    On 12/31/2017 1:05 PM, T Day [DynoMotion] wrote:
    Hello Tom,
    Looking for a way to have a pop up reminder.
    My VFD will run on Single or 3Phase, but its not recommended to run it on Single phase with my 10 HP motor.The 3 phase converter iam running allows the single phase 220 line to pass on through to machine, even with converter off.
    So what i need is a reminder to tell me to turn on phase converter. How could KMCNC be set to pop up a message the first time a spindle command is executed? Whether it be by Gcode or a button.
    Troy
    Sent: Sunday, December 31, 2017 4:19 PM
    I'm not sure I understand, but you might add a message box to the Spindle on (M3/M4) C Program such as "Converter ON?" with Yes No buttons. Halt without turning on the spindle for No.
    A Virtual Bit could be used as a flag to indicate whether the question has ever been ever answered Yes.
    It isn't clear when the Converter might be turned off and you would want to ask the question again. After Cycle Power on KFLOP? After relaunching KMotionCNC? After not running the Spindle for 5 minutes?
    Can you interface the Converter status to KFLOP?
    Regards
    TK
    On 1/3/2018 1:36 PM, 'T Day' [DynoMotion] wrote:
    Hi Tom,
    Do you have an example of using virtual bit as you described?
    Troy
    Sent: Wednesday, January 03, 2018 7:04 PM
    Hi Troy,
    Bits 48-63 are Virtual. They are guaranteed to be 0 on power up.
    So you would do something like:
    if (!ReadBit(48)) // is the bit set indicating the Operator answered yes?
    // no, ask the question
    // Operator Answered Yes - set the Bit to remember this
    SetBit(48);
    HTH
    Regards
    TK
    Dec 2007
    578
    Re: Pop Up Reminder
    Hi Tom,
    I altered my M3 c code program to have a Pop up asking if converter is on. And that much works. Now how can Pop up be skipped
    if the Virtual Bit 48 is set? Is there an ‘if ignore’ statement of some sort?
    Here is my program so far….
    Code:
    //Added Pop up to ask if 3 phase converter is turned on.
    #include "KMotionDef.h"
    #define TMP 10 // which spare persist to use to transfer data
    #include "KflopToKMotionCNCFunctions.c"
    main()
    	int Answer;
    	Answer = MsgBox("Is 3phase Converter On?",MB_YESNO|MB_ICONEXCLAMATION);
    	if (Answer == IDYES)
    		//printf("Answer is Yes\n");
    		SetBit(48);
    		ClearBit(148); //Spindle CCW bit
    		Delay_sec(.2);
    		SetBit(147); // turn on spindle clockwise
    	else
    		//printf("Answer is No\n");
    		ClearBit(48);
    		SetBit(147); // turn off spindle clockwise
    		SetBit(148); // turn off spindle counterclockwise
    Troy
    May 2006
    4045
    Re: Pop Up Reminder
    Hi Troy,
    Just use an "if" statement to only execute the message box stuff if the Virtual bit is NOT set.
    if (!ReadBit(48)) // is the virtual bit not set indicating the Operator hasn't already answered yes?
    (Note when posting code in cnczone you must un-tabify the text in order for the formatting to come out properly. There is a button in Visual Studio under Edit | Advanced untabify to do that for you)
    HTH
    Regards
    TK
    http://dynomotion.com
    Dec 2007
    578
    Re: Pop Up Reminder
    Hi Tom,
    Have it some what working now. When i MDI a M3 or M4 command it works. After pop up is answered YES, executing another M3 or M4 does not cause another pop up until bit 48 is cleared.This is good.
    But when i try to use the on screen CW or CCW spindle buttons, the first click of button there is no spindle movement and bit 48 gets cleared. Then after second click of button i get the pop up again, obviously because bit 48 got switched off.
    So why do the buttons not work like the M3 or M4 MDI command?
    Below is my code for M3. I think i formatted as you suggest. Iam not using VS, just copied code from Kmotion. Didnt see an option to untabify there.
    Code:
    main()
    int Answer;
    SetBit(48);
    Delay_sec(.2);
    else
    ClearBit(48);
    May 2006
    4045
    Re: Pop Up Reminder
    Hi Troy,
    Hmmm Its a bit technical but I think the issue comes about because if the Windows GUI Thread is blocking then the MessageBox can not be displayed. So the problem only arises when a GUI Button invokes the code. The push button is waiting for the code to finish, but the code can't finish because it needs to display a MessageBox, but the MessageBox can't display until the push button finishes.This is sometimes referred to as a deadly embrace.
    This has come up before and there is usually some reasonable workaround. But I don't see one in this case.
    Possible solutions could be:
    #1 change pushbuttons to never wait for Actions to complete
    #2 change pushbuttons to invoke actions from a worker Thread on the PC
    Please give us some time to come up with the best solution.
    TK
    Dec 2007
    578
    Re: Pop Up Reminder
    Hi Tom,
    Looks like i opened another can of worms No rush at all. Idea tho... would it make a difference if the buttons where set to execute the M code program?
    Troy
    May 2006
    4045
    Re: Pop Up Reminder
    Hi Troy,
    I was thinking along those lines but not really. The Spindle On button already does invoke the M3 Action. If M3 invoked the Interpreter to do something then it would be a re-entrant call to the Interpreter when M3 is called from GCode.
    Please see if this new Version Solves the problem. GUI Buttons that invoke actions now create a Worker Thread on the PC to perform the Action which releases the GUI Thread. Therefore if he Action need to display a message on the GUI and wait for a response it should work,
    KMotion 4.34k
    Changes
    Please let us know if there are any issues
    TK
    Dec 2007
    578
    Re: Pop Up Reminder
    Hay Tom,
    Sorry just getting back, been busy.
    I have v 4.34K installed. But still have same issue as before. When i execute a M3 or M4 by MDI pop up works correctly. But if i use the on screen buttons for turning on spindle, the first click causes the Virtual Bit to clear, then 2nd click causes pop up.
    Was there something c code wise i needed to change for this Kmotion version?
    Troy
    May 2006
    4045
    Re: Pop Up Reminder
    Hi Troy,
    I checked here and it seemed to work for me but I noticed a bug in the M3 C Program. The "if" condition when checking the Virtual bit doesn't have curly brackets to skip everything like we want. Without them it only skips asking the question but still does the rest which uses an Answer that wasn't ever asked. So the results could be wrong and unpredictable. Below is the corrected code.
    Code:
    main()
        int Answer;
                SetBit(48);
                Delay_sec(.2);
            else
                ClearBit(48);
    BTW On a related note when posting code to cnczone if you don't want to use Visual Studio to format and untab code you can change tabs to 4 spaces using the Find/Replace in KMotion. Right click at the beginning of the file, Find/Replace, Select Regular expressions, find /t (tab), replace with 4 spaces, then Replace All.
    Attachment 384730
    Thanks again for taking the time for this.
    Regards
    TK
    Dec 2007
    578
    Re: Pop Up Reminder
    Hi Tom,
    I tried code you posted and pop works but there is a different issue now. After user answers Yes, bit is set on and spindle starts. Then after spindle is stopped and a M3 or on screen button is executed the spindle does not start. Only way to restart spindle is to clear bit 48 using Kmotion. Also noticed that when trying to restart spindle, after pop up has been answered yes, that the Axis dros turn yellow then back to green and the jog buttons gray out.
    As for tabs in c code i didnt know that tabs should be removed and space used. Can using tabs cause issues? As iam sure i have them in other programs.
    Thanks again,
    Troy
    May 2006
    4045
    Re: Pop Up Reminder
    Hi Troy,
    Well duhhh. Once the Virtual bit is ever set we do nothing so of course the Spindle never comes on. The Virtual bit should just skip asking the question with an assumed response of Yes.
    Another issue that just occurred to me. If during a Job the Operator was to answer "no" then the Spindle wouldn't be turned on but the Job would continue which could be bad. So in that case I think the Job should be Halted.
    I've tried to fix those two issues in the code below:
    Code:
    main()
        int Answer=IDYES; // assume ok to turn on
        if (!ReadBit(48))// is the virtual bit not set indicating the Operator hasn't already answered yes?
            SetBit(48);  // set Virtual bit to not ask again
            Delay_sec(.2);
        else
            // if running a Job and Spindle isn't to be turned on Halt the Job
            if (JOB_ACTIVE)
                DoPC(PC_COMM_HALT);
    I don't see that here. Let's fix the issues above and then see if there is still an issue.
    There isn't a problem with using tabs or spaces. The only problem is with posting code into a cnczone post it looks ugly, indented improperly, and hard to read. So change all the tabs to spaces so it looks pretty.
    TK
    Dec 2007
    578
    Re: Pop Up Reminder
    Hi Tom,
    You say duhh, i say wow cause i dont know anything
    It appears to be working now. DROs still flash yellow and jog buttons gray. No worries for me unless it is a symptom of something else.
    Good catch on halting gcode if user selects no Tried this and even tho pop up is active the gcode continues until user answers No, then gcode halts.
    Noted on tabs, thanks.
    May 2006
    4045
    Re: Pop Up Reminder
    Hi Troy,
    Is this with an MDI or button?
    Check if you have "Exec/Wait" selected for the M3 Action. If set to wait then GCode should not continue until the User answers the question.
    Regards
    TK
    Dec 2007
    578
    Re: Pop Up Reminder
    Hay Tom,
    Its with both. This also happens when a M6 T is executed from GCode. This has always been like this, not just this version of Kmotion.
    Duhh.. moment for me. I actually knew about this one. It was set to Execute. Changing it to "Exec/Wait" fixed it.
    Troy
  1. A-CNC-G meting reminder feb 10th
    By rgee in forum Australia, New Zealand Club House
    Last Post: 02-08-2009, 02:37 PM
  2. Meting reminder for January 27 A-CNC-G
    Last Post: 01-21-2009, 12:56 PM
  3. A-CNC-G Metting Reminder 9th of December
    Last Post: 11-27-2008, 01:16 PM
