585,967 active members*
4,288 visitors online*
    Apr 2007
    32
    ZL15S alarm P/S 101 won't clear
    Control is the 0-TTB. I tried the PWE=1 power on w/reset but no luck. the alarm is on head 2 side so I'm thinking it somehow needs to be booted on in the head 2? I had both head 1 and head 2 PWE=1 at one point as well, but it only cleared the head 1 memory and still stuck with the alarm on head 2
    Apr 2007
    32
    Re: ZL15S alarm P/S 101 won't clear
    had a tech come out to fix it today. apparently there isn't a factory/official solution to this problem. the workaround was modifying the parameter for the program memory size (don't remember specifically what address it was) and that would force the control to clear/initialize the program memory to reformat it for the new memory size. just in case anybody else has an issue like this.
    Mar 2018
    5
    Send me in private message all parameters and PMC parameters.
  1. VM 40 II can't clear 1012 Sams Alarm
    By NovaSp in forum Hitachi Seikis
    Last Post: 02-07-2024, 04:46 PM
  2. Replies: 1
    Last Post: 04-07-2014, 03:57 AM
  3. LX3 Alarm code al14 how do I clear?
    By panaceabeachbum in forum Hyundai Kia
    Last Post: 01-06-2014, 07:58 PM
  4. cann't clear estop alarm after 4th was removed
    By dingo0722 in forum Haas Mills
    Last Post: 04-06-2012, 08:44 PM
  5. sl20 alarm 144 help need to clear
    By mkmk123 in forum Haas Lathes
    Last Post: 11-23-2007, 06:48 PM
