585,743 active members*
4,912 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > NVEM Ethernet controller custom mpg
    Question NVEM Ethernet controller custom mpg
    Hello guys, i have NVEM 6 axis ethernet controller and i want to use the pins for mpg with custom buttons e.t.c
    I connect everything and i can change Axis selection and probably Step selection, but i have no idea how/with what to control the movement from WHA+ WHA- pinout.
    I have a PS1010-20 Switch pulse rotary and thought i could but i can't find what i am doing wrong if it could.
    The pulse rotary need to add +dc voltage and gnd? Not enough pins for that
    Can you help me or point me the right direction to make it happened?
ID:	383292 Click image for larger version.
    Thanks in advance
    Re: NVEM Ethernet controller custom mpg
    No one have any idea? I use all combinations and nothing .
    Now i get this one https://www.ebay.com/itm/Rotary-Encoder-400P-R-6mm-Incremental-Optical-Shaft-Working-Measurement-5-2-Y0A1/252862587483?epid=857636894&hash=item3adfc8e25b:g0gAAOSwc-tY7yh9
    but again nothing change. I am thinking about the plugin of the board may is not the right even if i try all i find.
  1. NVEM Ethernet controller driver
    By GraemeT in forum Controller Cards
    Last Post: 02-10-2019, 10:51 AM
  2. CNC Ethernet Controller Recommendations
    By bmellis in forum Australia, New Zealand Club House
    Last Post: 02-28-2017, 09:26 PM
  3. Chinese Ethernet controller!
    By Azalin in forum Stepper Motors / Drives
    Last Post: 04-08-2016, 10:14 AM
  4. ETHERNET MOTION CONTROLLER
    By maellaguitars in forum Stepper Motors / Drives
    Last Post: 01-31-2016, 08:03 PM
  5. Best ethernet controller options out there....
    By Menatep in forum Stepper Motors / Drives
    Last Post: 05-12-2014, 04:10 AM
